Oil Light
Oil Light
How often do you guys see the oil warning light come on? I went for the first blast of the year today (Hooray!) and all was good! I still had a tiny bit of air in my brakes (but god knows where...) but this isn't the main issue. I had already done a good 30 miles, and after a pair of fairly hot corners, on a straight, the oil light flicked on. I grabbed the clutch, and glided into the nearest turning (about ten seconds away). The light was only on for a second before going off again. I'm not worried particularly, the bike still has all the oil I left with, but I'm just wondering how common this is?
Also, brake bleeding question!
Do I need to remove callipers and to turn and move them around to remove all air? I am certain that there is no air in the lines, M/C or the outer sides of the callipers. However the cat doesn't have a bleed nipple on both sides of the callipers, and is linked with that silly pipe. Is this my problem?
Tom...- 6Bronze
Number of posts : 52
Re: Oil Light
Brakes... that silly pipe is commonly blamed for failed bleeding.
Oil light... you know it is a level light rather than a pressure light? If there is oil in the sight glass then you are ok and it might be a sticky sender. I had this on my old XJ600.
Re: Oil Light
Nice one, thank you
Anyone had a sticky sensor on a cat?
Tom...- 6Bronze
Re: Oil Light
On my fist 'cat I found the light very occasionally came on when giving it welly up a steepish hill, the oil level was slightly down - was worrying at first.
The second 'cat has done it twice to me, both on the flat Autobahn, this time it wasn't oil level. Not a nice feeling, overtaking a car around 120, having another on your tail and seeing the oil light come on and stay on The second time it did it, I was going a lot slower. No idea what caused it, but haven't see it come on again after changing the oil and filter (not that I've been back to Germany to test it properly )
Re: Oil Light
When mine comes on it has always been going low on oil.
Mine eats a little I think as I have to top up every so often.
Tends to happen when going up hill / accelerating hard so I guess the sensor must be near the front.
On you calliper query - I've always done them in situ.
Give all the pipes a squeeze, try with steering all one way then the other, enough pumps on the lever to get good pressure at the lever and then gently ease off the bleed nipple making sure that you nip it up again quickly so as not to let any air in from the nipple.
The tie wraps on the brake lever / handlebar overnight works wonders too.
Good luck.
Good luck.
Re: Oil Light
My light comes on after taking a tight corner followed by hard acceleration, I topped the oil up slightly and it's not come back on, which tells me it was slightly low on oil and as I accelerate it picks up oil out the sump dropping the level just below the sensor
» My winter project.
» unical bike
» Number Plate Light Mod
» Low fuel light indicator
» thundercat with cbr600 rr rear light
» unical bike
