side stand
andy600r
hutch2064
side stand
my cat seems to lean quite far over on side stand is this the norm and if so has anyone found a fix for this.
hutch2064- 7Bronze
Number of posts : 84
Registration date : 2011-11-03
Re: side stand
has your bike been raised up at the back because iv heard that can affect the stand position. If not i dont know sorry
Andy
Andy
andy600r- 6Bronze
Number of posts : 59
Hobbies : job - plant operator. biking, drawing, mechanical interests
Registration date : 2011-10-02
Re: side stand
The stands do vary a lot in the amount of lean they cause.
Mine had the opposite problem and left the bike too upright. So much so that on one occasion, on an adverse camber and having just got off the bike, it actually fell away from me. :o Fortunately I caught it in time! Would have been hugely embarrasing
Post a pic up and folk can compare, but I'd rather it leant over further than not!
Chris
Chris
greencat- Admin2
Re: side stand
I think "They all do that, Sir."
It worried me at first, but I've just got used to it. I console myself with the thought that the bike won't topple over in the garage/car park/yard etc. if one of the tyres goes down overnight.
If the bike's been jacked up at the back to make the handling sharper, it will be more noticeable. If it hasn't, you could drop the front a bit to get the same effect on the handling and at the same time the bike won't lean so far on the stand.
If it really worries you, the easiest "cure" is to carry a bit of wood or plastic round in your pocket - either a proper puck or just some old skirting board.
Re: side stand
Tis true . . . if the bike has been jacked up it will effect the lean angle when on side-stand.
Another thing to check is . . . has the bike been lowered in it's history and the side-stand shortened to suit ? And subsequently been re-raised (to normal hight) and the stand not repaired/replaced ?
Re: side stand
0c's got his thinking cap on tonight for solving conundrums
If you still have to put a lot of effort into pulling it over I wouldn't worry about it.
You could get the measuring tape and camera out for the 'normal' cats to compare with.
Re: side stand
will mesure mine when i get a chance (hope this isn't going to go where i'm thinking it might) and re cat rear is normal...i think hagon rear shock...the front has been dropped about 25mm but am running a 120/70 on front, but there seems to be a lot of play where the side stand is bolted to frame.
hutch2064- 7Bronze
Re: side stand
Had the same problem on my bike with play in the side stand pivot, filed the jaws of the stand flat and fitted a shim to remove the play.
past-it- 6Silver
Re: side stand
Does anyone wonder why all bikes dont have a centre main stand. This been my first bike in a long time , it suprised me that alot of bikes dont fit them. Is there any provision for one on this bike.
PETERYZF- 1Bronze
Number of posts : 5
Hobbies : Self Employed Car Mechanic
Humour : Need course on bikes.
Registration date : 2012-03-09
Re: side stand
Sorry, no provision at all.
Think the exhaust gets in the way of one having been factory fitted (guess a cost saving element too).
Side Stand height
Hello All,
I was wondering where I could get a shorter stand as my bike has been lowered quite a bit, so the bike sits very upright indeed.
I have hunted ebay and most look totally rubbish.
NeilAllso- New Member
Number of posts : 1
Hobbies : bikes and guitars
Humour : dark as hell
Registration date : 2020-05-28
Re: side stand
If you can find a trusty engineer / welder then cutting a small section out below where the spring attaches and strongly welding up again could be an option.
Probably worth getting a spare thundercat sidestand to play with to allow you to put it back as it was if needed.
My only worry would be if it would be strong enough and if not then blame the engineer/welder.
Good Luck
Good Luck
