Bit of tidying up while replacing rear tyre
Bit of tidying up while replacing rear tyre Empty Bit of tidying up while replacing rear tyre
Post  yamahamad Fri Jun 23 2017, 21:46
New rear tyre time so as i took the wheel out thought i would tidy up the swingarm where a little rust was starting.
Bit of tidying up while replacing rear tyre C1BFEF04-7A4A-4EBE-941A-0945EB6BEE3E_zpsp5eucygy
Cleaned off the chain lube with brake cleaner & keyed the box section with a scouring pad & masked up ready for paint.
Bit of tidying up while replacing rear tyre 1CDAFD3A-8F00-4B7C-9033-B15D98C31BCC_zpswz4swgko
Bit of tidying up while replacing rear tyre 2324C952-B960-4832-BCF5-3B5376C89603_zpszyqeqlzg
Also cleaned up the rear wheel & removed/cleaned the sprocket in the parafin bath at work.
Bit of tidying up while replacing rear tyre 2A1B7352-7211-4FAB-87D9-133F41AD3CDF_zpscg7tts5c
Plan is re fit the wheel & off out for the day to scrub in the new dunlop tomorrow, anyone up for a meet at devils bridge or around that area give me a shout.
Bit of tidying up while replacing rear tyre Empty Re: Bit of tidying up while replacing rear tyre
Post  yamahamad Sat Mar 31 2018, 10:19
This was on photobucket? have they done a u turn & put it back to how it was?
