New rear tyre question
terry lees
I know there's probably a million and one different threads on tyre choice and a further million and one different opinions but I was wondering do people change both front and rear at the same time or are happy just to change the rear (for the same make/model/compound etc) if the front is okay.
Mine is showing little signs of wear on the front but the rear needs changing, was going to switch to pilot 3s front and rear but am now tempted to just throw a Dunlop Sportsmart on for now and replace them both next time, any thoughts?
Re: New rear tyre question
I do that quite alot, but the other way round, I tend to wear fronts before rears. Get part worns from my local tyre dealer for nowt and use em up till the rear needs a new one and then put a new pair on. This might cause some controversy with some members, but to be quite honest can't tell the difference. Goes without saying but of course both must be radial or crossply, you can't mix them.
terry lees- 4Gold
Number of posts : 1026
terry lees wrote: Goes without saying but of course both must be radial or crossply, you can't mix them.
It's not an Austin 7 Terry
robertcains wrote:terry lees wrote: Goes without saying but of course both must be radial or crossply, you can't mix them.
Yeah I'll be sure not to mix up my cross ply and radials Tel
It is a Sportsmart that I've got on the front anyway and from what I've ridden on it so far seems pretty sure footed in the wet and dry
ive always tried sticking to exact same make front and back went with mismatched once and didnt handle to well.
owen.dyer146- 2Silver
Number of posts : 185
Hobbies : workshop maniger mazda main dealer
Registration date : 2012-01-24
I very rarely change front and rear at the same time. I just replace individual tyres when they're worn to the point where I don't trust them anymore and/or the handling is getting noticebly worse.
I normally try to stick with the same make, if not the same model. Though with the FZ6, which came on BT020s, I did fit a Dunlop Roadsmart when the back wore out, keeping the Bridgestone on the front for several thousand more miles with no problems. And I didn't notice any big change when I did finally fit a matching Dunlop front.
So - if it's legal, and you're comfortable with it, and it seems to work OK, then I'd say go for it.
Try to stick to match brands/type if you can. But if the front is fine leave and just change the rear. I have done this many times over the years and few times on my Thundercat
» Stupid Question!
» The 10 Question Hotseat
» For Sale - Used Rear Tyre - Michelin Pilot Road 2 160 60 ZR
» Non cat question
» Newbie question
» Non cat question
» Newbie question
