33bhp A2 Licence Question
Ingyy
33bhp A2 Licence Question Empty Re: 33bhp A2 Licence Question
Post  Ingyy Wed Jul 09 2014, 11:36
ive just been on the phone to a yamaha dealer andthey are saying once i pass my a2 licence i have to ride something with 46 bhp? can i not ride anything with lower? /: as the only kit for tcat is 33bhp right? sorry if this is the wrong place i cant seem to find the right place still ggetting used to the forum, Thanks.
Ingyy
Ingyy
New Member
New Member
Number of posts : 3
Post  0ldcat Wed Jul 09 2014, 12:04
No Probs with where you've posted Ingyy. It'll show up as a new post and people can look and help if needed. We can always move the thread/post (if need be), at a later stage.
Why not pop along to the [You must be registered and logged in to see this link.] section and say Hi. I'm sure you'll receive a warm welcome.
Cheers & Welcome  Thumb
0ldcat (Tel)
Post  weasley Wed Jul 09 2014, 12:29
Find a new dealer. An A2 licence allows you to ride up to 35 kW (46 bhp). You can still ride a moped, or 125, or whatever, so long as it doesn't exceed the power and power-to-weight restrictions. You do have to take your test on a bike of at least 395cc and 20 kW minimum (27 bhp). Also your A2 bike, if restricted, must not be more than 70 kW when full power - here, the Thundercat may actually not be suitable.
Post  Ingyy Wed Jul 09 2014, 12:31
tcat is not allowed unfortunately :(
Ingyy
Ingyy
New Member
New Member
Number of posts : 3
33bhp A2 Licence Question Empty 33bhp A2 Licence Question
Post  0ldcat Wed Jul 09 2014, 12:57
Ingyy wrote:tcat is not allowed unfortunately :(
Maybe not to take the test, but once you have an A2 licence, ~ with a 33bhp restrictor kit fitted, does the Cat not then fit into the category of bikes you can ride ?
Post  0ldcat Wed Jul 09 2014, 13:10
Ingyy wrote:no because the power to weight ratio is still higher then it should be
Then it looks like you'll have to wait a bit for your Cat.  sad
Post  ellie Thu Jul 10 2014, 07:07
No cats can no longer be restricted which is a pity as mine was great restricted.
Post  weasley Thu Jul 10 2014, 07:28
The old fashioned restricted licence, which Ellie had, was 33 bhp maximum and any bike could be restricted.
The new fangled A2 licence is 45 bhp maximum but the bike must not be restricted from a bike that is more than 90 bhp when full-power. I think official numbers for the Cat put it just over this limit.
Post  0ldcat Thu Jul 10 2014, 10:49
weasley wrote:The old fashioned restricted licence, which Ellie had, was 33 bhp maximum and any bike could be restricted.
Hmm, it does indeedy 96bhp officially (despite owners & jurno's thinking/quoting 100bhp), which coincidentally is the same as a CBF1000 (06-09), non of which is any use to Ingyy sadly   sad
Post  Rosco Thu Jul 10 2014, 11:03
ellie wrote:No cats can no longer be restricted which is a pity as mine was great restricted.
That is what I thought when I was following you on a rideout.
I thought you were talking porkies about the restriction.
Post  OhJay Thu Jul 10 2014, 15:20
Restricting to 33 is even worse from what I can work out, the actual wording is "The motorbike must also not be derived from a vehicle of more than double its power." Source so does that suggest if restricting to 33bhp it can't have started with more than 66?
I think it's also done on engine power rather than "at the back wheel" power, I've had the same argument about the SRAD GSXR 600 which is mostly quoted low enough to be acceptable.
To answer the original question, you don't HAVE to ride 47 bhp, you can ride smaller if you want, but Thundercat isn't on the list.
OhJay
OhJay
Number of posts : 176
Post  0ldcat Thu Jul 10 2014, 19:36
Here is the DfT A2 licence acceptable list Click Here
Looks like this puppy (XJ6-n - restricted) is on there
Post  weasley Thu Jul 10 2014, 20:25
OhJay wrote:Restricting to 33 is even worse from what I can work out, the actual wording is "The motorbike must also not be derived from a vehicle of more than double its power." Source so does that suggest if restricting to 33bhp it can't have started with more than 66?
I think you have kW and bhp mixed up. The old 'A2' restricted licence (which was a 2 year restriction) was 25 kW or about 33 bhp; there're was no limit on what bike you could restrict. The current A2 licence limits you to 35 kW, about 46 bhp, and the bike can not be restricted from anything with more than 70 kW (about 93 bhp) as standard.
