HELP! Will not start
solved HELP! Will not start
Post  clark607 Mon Dec 30 2013, 13:57
Help needed.
I recently got back from working abroad. I had my bike on a battery management system while i was away, but the power to my garage was cut so the battery was flat on my return.
I manage to recharge the battery and the bike would turn over…... but will not start  fuming
I have have tried the spark plug test (ground) and there is no spark.
Things i have done.
1. New battery
2. New starter solenoid
3. New spark plugs
4. New Coils
5. Fresh fuel
I am at my wits end and any advice would be greatly appreciated.
Thanks in advance.
clark607
clark607
Number of posts : 27
Registration date : 2011-08-31
solved Re: HELP! Will not start
Post  SteveCat Mon Dec 30 2013, 14:45
Do you have an alarm / immobiliser fitted?
Post  clark607 Mon Dec 30 2013, 22:46
SteveCat wrote:Do you have an alarm / immobiliser fitted?
Yes i do, i have a SPY 5000m alarm fitted
clark607
clark607
Post  SteveCat Mon Dec 30 2013, 23:47
If it is anything like a Spyball, once the internal battery goes flat it's toast. I'll admit I hate alarms/immobilisers with a passion, so my biased view would be to eliminate that as as a possible cause.
Post  Guest Mon Dec 30 2013, 23:57
Hmmm...I've been toying with the idea of fitting an alarm. Might just stay clear of that now. Thanks Steve.  left thumb up
Post  clark607 Tue Dec 31 2013, 14:32
Thanks for your advise.
I will un-install the alarm so i can rule that out.
clark607
clark607
Post  mrfrance Tue Dec 31 2013, 14:38
Word of advice with the Spyball also, unless you pay a pro (or you really know what you're doing) these are a pain to "uninstall" ...I had one on my cat which had been deactivated but could not be removed because of how they are wired in, I would have needed to have a new loom fitted and no one would touch it!!
Sorry, it probably doesn't help.
Post  Wooster Tue Dec 31 2013, 17:27
I had to replace the loom on mine to get rid of the (dead) Meta Alarm that had been professionally fitted. :(
Post  clark607 Sat Jan 04 2014, 14:19
ok i have now un-installed the alarm and still no spark.
I have also tried taking the kill switch out of the loop and still nothing?
clark607
clark607
Post  bobh Sat Jan 04 2014, 22:00
Check if you get any sort of voltage reading (with a multimeter) on the L.T side of the coils.  Turning the engine over, you should see a fluctuating 0-12V reading, which may average out at somewhere in between, depending on the response of your meter and the speed at which the engine is turning over.  If you do, then the problem's probably on the HT side - coils, leads, plug caps.  If not, then you'll have to work back from there to see where the "blockage" is.
Last edited by SteveCat on Mon Jan 06 2014, 10:11; edited 1 time in total (Reason for editing : removed duplicate post)
Post  bobh Sat Jan 04 2014, 22:02
I'm seeing double - it must be the Cotes du Roussillon Villages Aoc red.....
Post  clark607 Sun Jan 05 2014, 13:21
all done Smile
After all that it was a faulty connection underneath the fuel tank.
Thanks for your help and advice.
Now i have to tidy her up ready for MOT.
clark607
clark607
