Bike wont fire up
Bike wont fire up Empty Bike wont fire up
Post  Dirt Bike Dave Fri Mar 13 2009, 16:28
Right, need help...Took the blade to bits before i went away to work last trip....came home 4 weeks later and built everything back up...have checked and re-checked all the electrical wiring is back as it was, refitted the tank and fuelled it up..
Bike is turning over but won't fire up....at the bottom of the tank there is a banjo fitting for the main fuel line to the injectors...Cant remember what way round it was pointing as its a right angle fitting...have it pointing so the hose doesn't kink when the tank is in place...am i right in thinking the holes on the clip and the hole in the bolt shouldn't need to line up??
i'm pretty sure its fuel related as the bike was running ok before i took it to bits..
Have cracked the other end of the tank hose at the injector rail and there is fuel coming out...next stop is the plugs i guess...major work up as i've just put it all back together
grumpy
Bike wont fire up Empty Re: Bike wont fire up
Post  Dirt Bike Dave Fri Mar 13 2009, 18:29
Update:
Getting fuel at the rail, looks like injectors maybe gummed up or not firing?? dropping fuel into the throttle body manually and it tries to go....
Post  furball Fri Mar 13 2009, 18:52
You are getting a spark at the plugs arnt YOU?????????????
You have the kill switch in the right position ??????????????
Look at the easy things first Dave sometimes saves alot of hastle
Davie
furball
furball
Post  Dirt Bike Dave Fri Mar 13 2009, 20:42
aye Davie,
i did check the obvious, will check the injectors tomorrow to see if they're firing or just gummed up...hope it's not the ECU..
When i was digging around before i found a connector from the regulator which had just about completely burnt out so i rejointed the wiring, ill check that again..was hoping this was why the bike was chugging at low revs..
Post  Dirt Bike Dave Sat Mar 14 2009, 09:54
shit happens
Sorted!! 1 cable off the power commander was connected wrong...swapped it over and vrooom..fired up first time...whoohoo..
A bit embarrassing me being a Lecky and all Embarassed
Bring on the sunshine..
Post  Rosco Sat Mar 14 2009, 21:28
slap'ed
All I've managed to do with my bike this year is TAX it....... Embarassed
I hope mine still works.
Will try and get out soon. Don't like it when I can still wheel-spin the car so easily on dem greasy roads.........big girls blouse!
Tryout for Wee Mac needs to be soon though!
Post  Dirt Bike Dave Sat Mar 14 2009, 22:54
Rosco,
I'll give you a call ..maybe next weekend for a wee blast??
Post  Rosco Sun Mar 15 2009, 09:49
Hi Dave
Aye.....Saturday morning/early afternoon might be ok but I need to be back early as I'm off out for Dinner and then the Comedy Club.
...Sunday is out....(Mothers Day)
Ross
