seat wont unlock
seat wont unlock Empty seat wont unlock
Post  sir digby Fri Jul 15 2011, 22:35
dam it i cant get my seat up turning the key but its not doing anything any scallywags know how to get it open another way think it could be my big lock in there thats jammed it help please
cheers
mark
sir digby
sir digby
Number of posts : 361
Hobbies : roofer/titting about
Humour : if iam put on life support machine turn it off and on again see if that works
Registration date : 2011-04-19
http://yorkhomeimprovements.com
seat wont unlock Empty Re: seat wont unlock
Post  robertcains Fri Jul 15 2011, 22:44
Have you tried pushing down hard on the seat whilst turning the key? sounds obvious but works sometimes
Post  sir digby Fri Jul 15 2011, 22:47
yea pushing,pulling sitting the wife on it and screwdrivers inside it not budging at all
sir digby
sir digby
Post  stretchie_ Tue Jul 19 2011, 11:40
When I locked my keys under the seat of the Thundercat (I learnt that trick from Gail Very Happy ) I GENTLY pulled the rear edge of the seat up and got the pretty girl next door with small hands to reach in and get them out, this method might help youto have a look in there.
I have just had the same problem as you on the BlackBird, key in, turns really easily but the lock would not release. Turned out that the cable had come loose near the lock where it grabs the seat so there was no tension to pull the tab out to release the seat.
I had to remove the rear seat cowl and then I could get to the mech under the seat.
Hopefully for you if you can bend the seat up CAREFULLY, you might be able to hold the cable taught so that the key will open the seat, what I did then was to cable tie the cable to the frame and it works fine again.
Hope this is relevant and useful.
Post  sir digby Tue Jul 19 2011, 20:15
thanks ill give that a try tomorrow
sir digby
sir digby
