Winter project!
+11
furball
supraloopy
Big sy
15 posters
Page 1 of 3 1, 2, 3  Next
Winter project! Empty Winter project!
Post  Big sy Tue Nov 22 2011, 17:44
hi all!
Well the time has come to garage the cat for winter, so what better time for a stip down, paint, rebuild and some mods!
This is my bike on the day i bought her,
Winter project! 223670_2186031203290_1022325419_2591541_6585196_n
since ive had her ive fitted longer mirrors with leds in, HID light kit (thanks Rosco) and an R6 shock.
With this being my first bike iv decided to really go to work on her, I decided to go for the R6 tail swap and have been collecting all the bits for the swap, so this morning i stripped her tail down got out my hacksaw and started cutting! scary knowing that after that first cut theres no going back! lol, So i spent 3 hours in the garage this morning and ended up with her looking like this!
Winter project! 2011-11-22134908-Copy
Winter project! 2011-11-22134836
The sub frame is fixed at the top, all i need to do now is cut a bit more of the main frame off, weld some plates on to it with some lugs for fixing the bottom arms of the subframe to, i haven't fitted the battery tray, under tray or rear light yet as ill be stipping her right down to the bare frame for powder coating.
So thats it for now, i will post as and when i progress with the work.
Cheers,
Simon.
Big sy
Big sy
Number of posts : 122
Registration date : 2011-08-19
Winter project! Empty Re: Winter project!
Post  yamahamad Tue Nov 22 2011, 21:24
Nice work mate, great to have another winter modification & repair thread on the go, a few of us this year it seems.
It looks like you are doing well but if you need any help there is a few r6 tail threads on the usa site.
Keep the pics coming.
Post  Big sy Tue Nov 22 2011, 21:35
Thanks mate, long way to go yet! the USA site is where I got the idea from for the tail swap, there are a few guys over there with R6 rear ends on there cats, some really nice bikes,
Cheers,
Simon.
Big sy
Big sy
Post  Big sy Thu Nov 24 2011, 13:25
Hi all,
So a little more progress on the bike this morning, I cut off part of the frame that was not needed and welded some angle iron on each side, Ive shaped and drilled them ready to hold the bottom legs of the sub frame, I then bolted it all together and it was a perfect fit, hight and all in line, so thats me happy! Very Happy
Winter project! 2011-11-22134238
Winter project! 2011-11-23120141
Winter project! 2011-11-24110308
Winter project! 2011-11-24122348
Winter project! 2011-11-24122333
Winter project! 2011-11-24123644
Cheers people, hope you enjoy reading this thread as much as im enjoying do the work! Very Happy
Simon.
Big sy
Big sy
Post  Guest Thu Nov 24 2011, 17:12
Shocked Shocked Winter project! 2011-11-24110308
I hope that you chamfered that plate before welding it on .
you need to turn your amp up a bit.
the welds lookes as they are just sitting on top.
also I would add a bit more support.
the reason why I'm saying this is that we don't want the back end snapping off whilst your riding it.
please don't be offended , I'm just thinking of your own safety. Wink
have a read of this. john
http://www.mig-welding.co.uk/mig.htm
Post  supraloopy Thu Nov 24 2011, 19:16
Nice project. But as Johnakay has said that weld does not look like its penetrated and you have ground what was sitting on top away to make it look nice. What welder are you using (amp wise) and as said above we don't want what you are sitting on snapping :0)
keep up the good work though.
Dave.
supraloopy
supraloopy
Number of posts : 178
Hobbies : Mechanic,body repairer/ music, my bike.
Humour : GIGGIDY GIGGIDY GIGGIDY...
Registration date : 2011-10-18
http://Dave@davewhittleservices.com
Post  Big sy Thu Nov 24 2011, 19:36
Thanks for the advice guys, that weld was my first attempt at it using my dads welder which I'm not familiar with, its 130 amp with gas, I thought it was on full power but after that weld realised it wasn't, so cranked it up and it penetrated a lot better, I grinder that weld down put a grove in it and welded it again.
Also I don't think there would be much chance of it snapping off as most of my weight will be supported by what's left of the of the original frame, and any weight that's put on the bottom legs of the sub frame are pushing against the frame rather than downward force on bracket, if you know what I mean?
Simon.
Big sy
Big sy
Post  supraloopy Thu Nov 24 2011, 23:33
Big sy wrote:Thanks for the advice guys, that weld was my first attempt at it using my dads welder which I'm not familiar with, its 130 amp with gas, I thought it was on full power but after that weld realised it wasn't, so cranked it up and it penetrated a lot better, I grinder that weld down put a grove in it and welded it again.
Simon.
Great news. Just don't want a refurb/rebuild/modify thread to turn into a fatality thread in 5 months time nonofinger
supraloopy
supraloopy
Post  Big sy Fri Nov 25 2011, 16:59
Spent a few hours on the bike today, stripped her right down to the frame, i just cant seem to get the swing arm bearing out or the head bearing seat things, think ill nip down my loacal bike shop and get them to do it.
It was really easy to strip down with no problems, i took lots of photos and notes of where things went and what was conected to what ect, but im still bricking it about putting her back together, im worried ill forget where bits go and which way cables are routed, Iv got a haynes book so ill hope for the best!
Heres a few a pics of todays efforts!
Winter project! 2011-11-25120331
Winter project! 2011-11-25133444
Winter project! 2011-11-25142454
Winter project! 2011-11-25142503
Winter project! 2011-11-25151229
Winter project! 2011-11-25155945
Cheers,
Simon.
Big sy
Big sy
Post  SteveCat Fri Nov 25 2011, 17:12
Moved the thread
Post  Big sy Fri Nov 25 2011, 17:16
SteveCat wrote:Moved the thread
cheers, wasnt sure if it was in the right place.
Simon.
Big sy
Big sy
Post  supraloopy Fri Nov 25 2011, 21:34
BTW that Mig welder is well capable for what you need just up the power and use Argon/oxygen mix gas or better;0) Lookinggood and I know how that big pile of bike bits looks ;0)
Dave.
supraloopy
supraloopy
Post  HEHORE Fri Nov 25 2011, 22:44
I THINK YOUR NUTS!!! , not somthing i would attempt , but enjoying the pics and watch the progress
Post  Dirt Bike Dave Sat Nov 26 2011, 03:54
wuuff!! my granny could weld better than that...
Well that's not entirely true..my granny canny weld at all...partly because she's no longer with us and partly because she was never a welder during her long and happy life..
My point is mate, if you wanna test how good the welding is get a local company to do an NDT (non destructive test) on the welds to see how strong/good they are..I aint gonna rip the piss about how good it looks or how strong it might be as it might be fine no matter how it looks or it might look good but be a crap weld structurally ( not sure i spelt that correct).. For your own piece of mind i would get any loadbearing welds checked properly..any local engineering company should be able to do that for a nominal fee..
For insurance purposes eg modifications it might be required, i'm not 100% on the legalities of all the shenanigans.. but for your own piece of mind it surely has to be worth it ..
I take my hat off to ya for having the balls to do it tho...thats what makes all this biking palaver such good fun..
It's always good to step out and do summit different!
looking forward to seeing the end result.
Post  Big sy Mon Nov 28 2011, 12:23
Haven't done much over the weekend, You'll be glad to know Ive re-welded the plates, Ive had them checked out by a friend who is a welder by trade and he's given me the ok Very Happy
Ive freshened up the engine and taken the carbs off only to find the intake boots are perished, there not perished right through but id like to get some new ones if i can find them cheap enough, not sure where i can get some from at a good price, they seem to be expensive, as they have not split right through i might just settle with rubbing some silacone in the splits, also theres 4 pipes that come off each of the intake boots which are blocked off, im guessing there for carb balancing gauges? 1 was split in half and 1 was disconected, which might explain why she doesnt like to run smothly between 1-3k.
Im now waiting on the swing arm bearings to be pressed out at an enginering place, he's not sure weather he'll be able to press them out as you cant press the bearings right through from 1 side to the other, ill find at out 3 oclock, then once thats done off to the powder coaters and hopefully they'll be able to fit it in before xmas, then i can start slowly building her up Very Happy
Simon.
Big sy
Big sy
Post  Guest Mon Nov 28 2011, 16:18
if your replacing the bearings(to which it might be best)
put heat to it.
heat it up all around the outside of the bearing frame.
use a long drift bar(solid round bar preferably brass but steel will do if edges are rounded off) put it through the other end.
and tap around the outer bearing shell.
it should pop out.
then the same to the opposit end.
try not to heat the bearing to much as you just want the out bit to swell up etc.john
Post  Big sy Mon Nov 28 2011, 17:06
Thanks for the advice John, my friend did exactly that, heated one side then knocked it out with a drift and then used his press to get the other one out, he only charged me £10 with i thought was good, new ones should arive tomorrow.
So after that i took the frame, sub frame and swing arm to the powder coaters, its been done in satin black and all for £120 which i think is very reasonable, there stacked out with work but he's going to try his best to get it done before he shuts up shop for xmas.
I just need to know where to get some cheap carb boots from now, ive tryed fleebay, yambits and weemoto with no luck, main stealers are £35each! so can anyone please point me in the direction for some cheaper ones?
Also while the carbs are off im gonna take them apart and clean them, ive done this before a long time ago on an old DT carb, i think if i do one at a time and take my time i should be ok, any tips welcome, also while there apart is it worth me putting bigger jets in? dynojets or something else? im not to worried about loosing fuel economy, any advice would be great,
Cheers,
Simon.
Big sy
Big sy
Post  furball Mon Nov 28 2011, 17:28
I've used black silicon, on the carb boot of a GasGas trials bike before without any problems, not sure if it would have the same effect on a full on sports bike..
Gave them a good clean with carb cleaner first, let them dryout for a few hour's, then worked the silicon into the cracks..
Davie
furball
furball
Post  Big sy Mon Nov 28 2011, 17:33
furball wrote:I've used black silicon, on the carb boot of a GasGas trials bike before without any problems, not sure if it would have the same effect on a full on sports bike..
Davie
Cheers Davie, i think that'll be the plan, they haven't split right through so i guess the silcone will prolong the life of them a bit more.
Simon.
Big sy
Big sy
Post  Big sy Sat Dec 03 2011, 07:41
Well spent last night cleaning the carbs, took me about 90 minutes to strip down clean and rebuild, I used a good carb cleaner and compressed air to clean the jets but I left the mixture screws alone as I didn't want to mess up the settings, it was surprising easy!
I also used some clear gasket sealant to sort out the perished/cracked intake boots, it worked a treat! :-)
Now I'm just waiting for the frame and swing arm to come back from the powder Coaters.
Simon.
Big sy
Big sy
Post  stretchie_ Sat Dec 03 2011, 19:47
Good on you, get the pics up when you get the fame and stuff back
Post  Big sy Wed Dec 14 2011, 19:30
Hi all,
got the frame back end of last week also my Hagon fork springs arrived, so i spent a couple of hours monday and all tuesday morning doing a bit of work.
Winter project! 2011-12-12091013
Winter project! 2011-12-12090943
Im really happy with the satin black finsh.
Winter project! 2011-12-12100031
Winter project! 2011-12-12110027
Had a go at changing the fork springs, oil and seals, iv gotta say its a lot easier that i thought! piece of p1ss! Very Happy
Winter project! 2011-12-07232702
Winter project! 2011-12-13123042
Iv also sprayed the clip ons and yoke satin black, they look awesome! Very Happy and fitted the new head stock bearings.
well thats it for now, gonna have a couple of hours on it in the morning before work, not sure what im gonna do yet.
Cheers folks!
Simon.
Big sy
Big sy
Post  supraloopy Wed Dec 14 2011, 22:12
Looking good there Si. Keep up the good work!! I'm just waitng for bits and then I'm almost done ;0)
supraloopy
supraloopy
Post  Snowcat Wed Dec 14 2011, 23:03
Blimey when you guys put a bike away for the weekend you certainly go to work!!
Not even fitted my heated grips yet, let alone refurb the rear shock, better get my ass in gear Smile
Post  supraloopy Wed Dec 14 2011, 23:05
stevedj2000 wrote:Blimey when you guys put a bike away for the weekend you certainly go to work!!
great rofl
supraloopy
supraloopy
