Breaking thundercat
+12
prodigy
frazmcfraggle
kingnathski88
sir digby
Wowey
sn1ke
joshhatton
bm1957
16 posters
Page 1 of 3 1, 2, 3  Next
Breaking thundercat Empty Breaking thundercat
Post  bm1957 Sat Aug 06 2011, 12:27
Everything will go onto e-bay (easy bits first then the rest as I learn to take it apart!), but thought I'd offer here first.
It's a 2001 yellow/silver/black, although the fairings are a bit tired.
Pics/prices on request
E-bay link
bm1957
bm1957
5Bronze
5Bronze
Number of posts : 41
Registration date : 2010-02-21
Breaking thundercat Empty Re: Breaking thundercat
Post  joshhatton Sat Aug 06 2011, 18:44
heya
i need
sump urgent!!
and exhaust
thanks!
joshhatton
joshhatton
5Bronze
5Bronze
Number of posts : 44
Registration date : 2011-04-23
Post  bm1957 Sat Aug 06 2011, 20:47
joshhatton wrote:heya
i need
sump urgent!!
and exhaust
thanks!
you have first dibs (and PM)
bm1957
bm1957
5Bronze
5Bronze
Post  sn1ke Mon Aug 08 2011, 10:05
How much for the indicators?
sn1ke
sn1ke
New Member
New Member
Number of posts : 2
Registration date : 2011-08-08
Post  bm1957 Mon Aug 08 2011, 21:15
sn1ke wrote:How much for the indicators?
Front indicators?
They're fine externally but the internal fixing plate on one of them is a bit bent and a pain to fit -£20 the pair delivered
Rear indicators?
Both good (as far as I know - never had them off!) - £25 the pair delivered
bm1957
bm1957
5Bronze
5Bronze
Post  SteveCat Mon Aug 08 2011, 23:18
and for the saddle/seat?
Post  bm1957 Tue Aug 09 2011, 07:35
SteveCat wrote:and for the saddle/seat?
Seat has no damage to main section but wear to front corners (through to the plastic) hence £15 + postage
PM me you mobile no. if you want pics (or I can post pics but that will take longer)
bm1957
bm1957
5Bronze
5Bronze
Post  Wowey Tue Aug 09 2011, 08:42
hi there
rear brake pads & or assembly?
Wowey
Wowey
Number of posts : 366
Hobbies : NHS, love bikes and horses
Registration date : 2011-05-04
Post  sir digby Tue Aug 09 2011, 09:15
hi mate can i bagsy the mirrors only need the near side one really but ill buy both if you dont want to sell seperate let me know how much
cheers
mark
sir digby
sir digby
Number of posts : 361
Hobbies : roofer/titting about
Humour : if iam put on life support machine turn it off and on again see if that works
Registration date : 2011-04-19
http://yorkhomeimprovements.com
Post  bm1957 Tue Aug 09 2011, 18:26
sir digby wrote:hi mate can i bagsy the mirrors only need the near side one really but ill buy both if you dont want to sell seperate let me know how much
cheers
mark
Hi Mark
The right mirror is good but the left is a bit tatty (the retaining bolt is rusty and may not be original, the black is more grey).
Left mirror £10 delivered
Right mirror £10 + postage
bm1957
bm1957
5Bronze
5Bronze
Post  Panzerbuilder Tue Aug 09 2011, 19:33
Mark,
Can I have the attachment bolts and brake line hose clips that attach the rear part of the front mudguard to the forks?
Let me know how much if available.
Post  bm1957 Tue Aug 09 2011, 20:02
Panzerbuilder wrote:Mark,
Two bolts and clips? PM me your address and I'll stick them in the post mate.
Ben (not Mark - he wanted the mirror!)
bm1957
bm1957
5Bronze
5Bronze
Post  kingnathski88 Tue Aug 09 2011, 23:03
hi, are the tyres any good on this? need front and rear part worns to get me through for a while. cheers, nathan
kingnathski88
kingnathski88
New Member
New Member
Number of posts : 2
Registration date : 2011-08-09
Post  bm1957 Wed Aug 10 2011, 07:08
kingnathski88 wrote:hi, are the tyres any good on this? need front and rear part worns to get me through for a while. cheers, nathan
Hi Nathan
tyres are good (rear almost new - 200 miles) but may have been sold already. I'll let you know next week if they don't go.
bm1957
bm1957
5Bronze
5Bronze
Post  kingnathski88 Wed Aug 10 2011, 13:48
Thanks, can you pm what you'd be after if there still going? Also need the casing for the right hand side, is it called the crank case cover? Nathan
kingnathski88
kingnathski88
New Member
New Member
Number of posts : 2
Post  frazmcfraggle Wed Aug 10 2011, 21:55
Hi mate, how much for headlight unit including retaining clip, dust cover / coil and ht leads / clutch lever / front calipers - if you can give me individual prices and an all in that would be great
frazmcfraggle
frazmcfraggle
Number of posts : 182
Hobbies : On The Buses
Humour : Sarcastic / Cheeky
Post  TomCom Tue Aug 16 2011, 21:59
anybode have front right fairing?
Post  prodigy Thu Aug 18 2011, 10:18
If it's still available and in good condition I might be interested in the Generator cover from the left side, says Yamaha across the middle.
prodigy
prodigy
Number of posts : 119
Humour : Yes please....
Post  TomCom Thu Aug 18 2011, 17:36
i need someone help to paint fairing Smile
Post  mrfrance Thu Aug 18 2011, 20:23
Hi how much for the clutch cover? (left hand side engine case)
Post  prodigy Fri Aug 19 2011, 08:19
mrfrance wrote:Hi how much for the clutch cover? (left hand side engine case)
The clutch cover is on the right side, on the left side is the generator cover I asked about a few posts before ;-)
prodigy
prodigy
Post  Rosco Fri Aug 19 2011, 09:01
If you sit on the bike (forwards!!!) the clutch cover is at you left leg.
0% sure!.......I'm a dafty!
The alternator cover and the biggest cover (name escapes me) would be at your right leg.
OK - I'm a dafty, My engine must be on backwards. It is the clutch cable that goes down to the front sprocket cover that made me think this was the clutch cover.
Post  prodigy Fri Aug 19 2011, 09:15
From Haynes under "Clutch removal":
"1 Drain the engine oil (see Chapter 1).
2 On YZF models, remove the right-handl
fairing side panel (see Chapter 8, Section 3).
3 Working evenly in a criss-cross pattern,
unscrew the clutch cover bolts (see
illustration). Lift the cover away from the!
engine, being prepared to catch any residual oil
which may be released as the cover is removed."
Why would we remove the right fairing panel to access a cover on the left side of the bike?
Also from haynes this image
Breaking thundercat Yamcover
This cover in the image is on the left side of my bike as I sit on it, I can see it out of my window!
prodigy
prodigy
Post  prodigy Fri Aug 19 2011, 09:16
Clutch cover and the starter cover are on the right side I believe.
See parts here
Or this rathe large looking clutch cover gasket here
prodigy
prodigy
Post  mrfrance Fri Aug 19 2011, 09:46
That is on the left hand side!! The one where you put the oil is on the right hand side!!
