Funny sound
Funny sound Empty Funny sound
Post  swannie Sat Feb 10 2018, 10:13
Good day
Im worried because of a funny sound when i turn my bike egnition on. I have a 2000 model thundercat and when i bought it, the sound was there but i read that its to warm up the bike so i always waited a few seconds before starting, but the sounds repetitions is faster now and doen not slow down and suddenly it stops but the bike wont start. Please i need advice.
My bike means alot to me. I love my cat
Please help?
My email is swannie467@gmail.com
My number is +27745433775
Thank you in advance
swannie
swannie
New Member
New Member
Number of posts : 1
Registration date : 2018-02-10
Funny sound Empty Re: Funny sound
Post  weasley Sat Feb 10 2018, 14:42
You are probably referring to the fuel pump, which whirs for a couple of seconds when you turn the ignition on. The length of time it whirs for depends on how much remaining fuel is already in the fuel system; the longer you leave the bike, the longer it whirs (until it times out at around 5s IIRC).
If it is whirring a long time every time you turn it on, perhaps there is a fuel delivery issue somewhere? Just to check, there is fuel in the tank, right? And the fuel tap is open?
Post  robertcains Sat Feb 10 2018, 15:00
As Paul says above,
The fuel pump ticks very fast as it primes the carburettors, if it’s been stood for some time you may need to switch off the ignition & repeat, when the carburettors are fully primed the ticking will noticeably slow down before it’s ready to attempt to start the bike.
Both my Thundercat & Exup follow(ed) this process & can easily flood the bike if attempting to start the bike too soon.
Post  bobh Sat Feb 10 2018, 18:57
A blocked fuel filter might cause this.
There's also the known issue with old fuel, particularly supermarket 95-octane, leaving a deposit in the carbs when it evaporates, that can block up the jets.
Post  yamahamad Sun Feb 11 2018, 10:45
Possibly a kinked or collapsed fuel line?
