Bought another One
The White One
Bought another One Empty Bought another One
Post  The White One Wed Aug 17 2016, 18:46
Won this today, hopefully picking up at weekend. Did I get a good deal?
http://www.ebay.co.uk/itm/YZF600r-Thundercat-/142078164761?_trksid=p2047675.l2557&ssPageName=STRK%3AMEBIDX%3AIT&nma=true&si=oYzUduvh00yPzuBZ9RTQwsEsY3w%253D&orig_cvip=true&rt=nc
The White One
The White One
Bought another One Empty Re: Bought another One
Post  SteveCat Wed Aug 17 2016, 19:45
looks good, mirror corrosion, get some Thunderace or what Weasley has on his. Take it has all 6 gears? Wink
Might need to do a carb clean, but you'll be on top of all of that - first thing a sprocket change?
Post  The White One Wed Aug 17 2016, 20:10
You got it Steve, I'm so going to rag it in 2nd, I've missed it that much lol. I have a couple of spare mirrors in better nick so I'll swap those over, change rear to a 49 tooth, carb sync, full fluids and filter change, check pads and calipers are all in order, wash her as she looks like she could do with one then use and abuse her (in the nicest possible way of course)
This will give me the time I need to sort out 2nd on the track (to be) cat/750/R6.
Also does anyone know what a K&N Power Commander is on a carbed bike? Does it plug into the TPS?
The White One
The White One
Post  Rosco Wed Aug 17 2016, 22:13
I've only ever bought Thundercats from guys called Neil.
Hope it is a good one.
Love the cats colours.
Post  past-it Wed Aug 17 2016, 22:25
K&N as always are filters (not much different to the original filter ), but as to the power commander??????????????? no idea why on a carb bike, unless he means he's fitted a dyno jet kit.
Post  The White One Wed Aug 17 2016, 23:11
past-it wrote:K&N as always are filters (not much different to the original filter ), but as to the power commander??????????????? no idea why on a carb bike, unless he means he's fitted a dyno jet kit.
Maybe he missed the apostrophe and should read K&N, power commander.
I did some research and they did do a "power pack" for carbed bikes but apparently it didn't make a big difference, I'll see tomorrow when I pick it up.
The White One
The White One
Post  yamrdtez Thu Aug 18 2016, 13:44
looks a great deal, 1 owner spring-wow ENJOY wink thumb up
yamrdtez
yamrdtez
Number of posts : 119
Registration date : 2016-03-17
Post  Radar Thu Aug 18 2016, 23:52
Looks like you done well there
Post  The White One Fri Aug 19 2016, 15:02
Got it home safe and sound, Full service history, every MOT certificate, totally original bar full exhaust system and the "power commander" it does plug into the tps and fine tunes it at throttle openings. Have the receipt for it and limited run, cost £165 new, wonder what it's worth now. The guy definitely under sold it.
Already replaced broken clutch lever, and swapped mirror over. Will sort out fluids and wash tomorrow when hopefully it's not raining
The White One
The White One
