Water Pump Failed, is TCAT 97 Water Pump same as R6 any years?
uniquetcatfreak
Water Pump Failed, is TCAT 97 Water Pump same as R6 any years? Empty Water Pump Failed, is TCAT 97 Water Pump same as R6 any years?
Post  uniquetcatfreak Tue May 31 2016, 18:08
Hi,
I've got a wanted post for a good condition replacement water pump on the forum, but looking on line does anyone know if an R6 water pump is the same?
uniquetcatfreak
uniquetcatfreak
Number of posts : 27
Hobbies : Motrocycles, Beer, Snooker
Registration date : 2015-07-09
Water Pump Failed, is TCAT 97 Water Pump same as R6 any years? Empty Re: Water Pump Failed, is TCAT 97 Water Pump same as R6 any years?
Post  past-it Tue May 31 2016, 18:13
Never really looked but to be honest the engines are different so I suspect that the pump would be as well.
Post  weasley Tue May 31 2016, 18:26
I doubt it. More likely to be the same or similar in a FZS600 or even a FZR600R.
Post  The White One Wed Jun 01 2016, 21:29
Do you just need the pump itself? I have one in the shed and one on an engine both 0f a 97/98 cat.
The White One
The White One
Post  uniquetcatfreak Thu Jun 02 2016, 16:57
PM sent Very Happy
uniquetcatfreak
uniquetcatfreak
Post  James Justice Tue Jun 28 2016, 09:52
Stupid question probably but how do you know if the water pump is gone or on its way
James Justice
James Justice
Number of posts : 19
Registration date : 2015-07-19
Post  SteveCat Tue Jun 28 2016, 10:15
One sign is if you see coolant leaking out of the pump, it has two seals one being the outer and at first glance you'd think this has gone but there is also an internal seal. When this one goes the safety mechanism is to let water out of the casing, in this case a new pump is required.
Post  uniquetcatfreak Tue Jun 28 2016, 16:18
+1 SteveCat
uniquetcatfreak
uniquetcatfreak
