Water pump oil leak
Water pump oil leak
Hi guys,
Thought i'd cracked the oil leak on the cat (or rather, the garage did), however, it seems it's still there.
Decided to give the bike a run with the side fairings removed so I could see better where it was coming from, without the fairings redirecting the oil flow. It would seem to be coming from the seal between the water pump and the engine.
Has anyone had any experience with this? I assume there's oil on the engine side of the seal. Is is a simple job to change the seal?
Gary.
Gary.
gazzaboy35- 5Bronze
Number of posts : 44
Humour : Sarcasm is stupidity's reward...
Registration date : 2011-12-31
» Water Pump Failed, is TCAT 97 Water Pump same as R6 any years?
» Coolant leak
» Toe in the water
» The Eifel - Test the water 2
» This will make your eyes water
» Coolant leak
» Toe in the water
