Rough running
Rough running
I am hoping this is just because i have not ridden it much and still used to twins/triples. At low revs it sounds odd, hard to describe but i would say kind of choppy. It could be simply that i am not revving it enough but at anything around tickover whilst moving it does not sound healthy. It does not feel rough just sounds it. I am guessing it is possibly not jetted for the exhaust fitted but could equally just be that i am not used to it.
Is this normal or is it something i need to investigate further ?
Re: Rough running
Might creating a video (perhaps to be shared via YouTube) be helpful to let the experts hear it ( and see the rev counter too)
Not sure how easy that would be whilst moving however unless you've got a talented helpful helper/pillion.
Good luck
Good luck
Re: Rough running
It sounds the same as mine and I've been told by mechanic it just needs the carbs balancing so hopefully it's just that. Although I also need mine rejetting to due to aftermarket pipes.
Either way it's nothing to worry too much about
Re: Rough running
What pipes have you installed "dudeofrude" as most manufacturers I've looked at state "no re-jetting required"!!!
Catnapper- 6Silver
Number of posts : 365
Hobbies : Motoring, DIY
Re: Rough running
I'm not sure which manufacturer they are but stainless pipes with a 2 inch wide straight through race pipe (sounds the dogs doo dahs) but has lost some midrange since they've been on so I'm thinking it could do with a stage 1 jet kit
Re: Rough running
Ahhh I now remember you asking about them
Catnapper- 6Silver
» Rough running / lumpy
» Running problems with new purchase
» Thundercat Running Temperature
» thundercat running probs!!!! heeeelllppppp!!!!!!
» Running TCAT for pub hopping - fairing, lights, clocks etc not needed
