Rough running / lumpy
Rough running / lumpy Empty Rough running / lumpy
Post  timboellis Fri Mar 04 2011, 15:28
Well bike running fine, however just came home from lunch just now and it was running a bit lumpy fits and starts if that makes sense, left it for about 1 - 2 mins to warm up but do i need to leave it running a bit more that that before taking off or is it something else?
timboellis
timboellis
Number of posts : 73
Hobbies : IT Support
Humour : Some
Registration date : 2011-02-20
http://www.piggywig.co.uk
Rough running / lumpy Empty Re: Rough running / lumpy
Post  Panzerbuilder Fri Mar 04 2011, 16:05
T,
If your on about the choke... Then I leave mine full on until the revs raise up to around 3-4k then I drop it off to 1/2 choke so the revs drop to 2k (not accurate but higher than normal tickover.) I then ride to the tenfoot gate and turn the choke off. All this is done in less than 1 1/2 minutes.
When I initially got the bike I didnt realise how much you needed to pull the choke lever to ensure you had full choke on. Since I realised this it starts fine everytime.
Cheers Rich.
Post  timboellis Fri Mar 04 2011, 20:24
Thanks will give that a try the morrow onway to work
timboellis
timboellis
Humour : Some
Post  kwakkat Sat Mar 05 2011, 10:29
cold day you have to watch out for carb icing runs likes its only running on 3 was it i used wyinn,s dry fuel to stop it there are others you can use too
pete
kwakkat
kwakkat
Post  mechy69 Sat Mar 05 2011, 11:28
If you have had it stored over winter? then fuel could have gelled, then as pete said, wynns or silkolines pro fst fuel add etc should solve it
Pete
