Heated Grips
Heated Grips
Anyone know which sets fit the thundercat - there are sooo many different ones!!
bigbazzaaaa- 2Bronze
Number of posts : 11
Registration date : 2014-07-09
Re: Heated Grips
Any of them which fit 22mm bars.
Re: Heated Grips
ok cheers and well ones that have twin throttle cable attachments as I got a set and its a single cable only
Re: Heated Grips
Not sure I understand.
The heated grips will have one (electrical) cable, the throttle assembly has two cables .. the heated grips slide onto the throttle assembly nylon sleeve.
Re: Heated Grips
To be clear, the existing rubber grip will pull off of the twisty throttle bit, leaving a plastic sleeve behind. Your new grip then pushes over this. You do not replace the throttle tube assembly (twisty bit).
» Heated Grips Vs Heated Gloves
» Brrr....
» Heated grips
» oxford heated grips
» Oxford Heated Grips £42.74
» Brrr....
» Heated grips
