piece of metal needed please
On all my previous bikes I have replaced the meep meep horn with a stebel air horn. Im struggling to fit it to the cat in one piece so I have decided to detatch the compressor from the horn part, locate the compressor in the boot and run an air line to the horn which I am locating near the oem horn. Due to the slight delay as im using the compressor remotely im keeping the oem horn where it is.
what im in need of is a piece of metal 5 inch long, one inch wide and of sufficient rigidity. 1mm up would be good as its not carrying much weight, only the plastic hooter. Size is only rough, I can cut down whatever I can get.
Ill be able to mount both horns from the oe mounting point but im struggling to get a piece of metal.
Does anyone have a piece knocking around I can buy, or have you any suggestions? All I can get is big sheets and thats not needed.
thanks
thanks
prime- 6Silver
Number of posts : 376
Re: piece of metal needed please
I've got my horn (Screaming Banshee) under the seat and it is still very loud.
Krusty has a Steibel (not sure the exact model) and managed to squeeze it behind the side fairings at the seat.
First thing that springs to mind is a local ironmongers who sell single mending plates, should set you back a quid.
i.e. [You must be registered and logged in to see this link.]
Wooster wrote:First thing that springs to mind is a local ironmongers who sell single mending plates, should set you back a quid.
thats great, thatd do the job nicely
Cheers mate good idea
prime- 6Silver
ive heard of people putting them under the carbs somewhere but couldnt find anyway to put it under front fairings. Didnt think of side fairings. Think woosters mending plate idea is a winner, should be able to bodge it up nicely with them.Rosco wrote:I've got my horn (Screaming Banshee) under the seat and it is still very loud.
Cheers mate
prime- 6Silver
Drop me a pm with your mobile number and I'll ring you tomorrow, I'll sort you out with something
Chris I work for an aluminium & stainless steel stockholder and I can get you any piece of metal you want, cut to size, drilled, folded, whatever.
Give us a bell if you still need may and I will oblige no
Problem.
Problem.
Thanks mate, im sorted now though pal. I ordered the mending plates as suggested and they were just what I needed. Buggered the horn up though so it was to no avail
prime- 6Silver
![-](https://2img.net/i/fa/m/tabs_less2.gif)
» IXS 2 PIECE LEATHER SUIT
» 2 piece leathers size 46 wanted
» Dainese Two Piece suit good condition uk size 40 euro 50
» Battery needed.
» bits needed
» Battery needed.
» bits needed
