Instrument panel upgrade
Instrument panel upgrade Empty Instrument panel upgrade
Post  Ziggy-whiz Mon Feb 17 2014, 10:00
Hi there has any1 changed there clocks for LCD or know how I might go about it would be a nice upgrade if it will work thanks
Ziggy-whiz
Ziggy-whiz
Number of posts : 9
Hobbies : Fixing things tht dnt need to b fixed
Humour : Sick and twisted
Registration date : 2013-10-08
Instrument panel upgrade Empty Re: Instrument panel upgrade
Post  SteveCat Mon Feb 17 2014, 10:51
The subject has been brought up a number of times, but I don't think anyone has actually done it.
I saw one being fitted to an early Ninja. The speedo pick up on this LCD unit was fitted to the rear wheel. There is no fuel gauge as there is no sender unit in the fuel tank to connect the display to.
I cannot remember what issues the guy had with the fitting, but I do know there were problems.
It did look good when it worked, not good enough though to tempt me to go through what he did.
Post  Ziggy-whiz Mon Feb 17 2014, 20:21
Damn will just have to get some new dials instead lol
Ziggy-whiz
Ziggy-whiz
Number of posts : 9
Post  Ziggy-whiz Mon Feb 17 2014, 20:50
How about just the speedo any ideas??
Ziggy-whiz
Ziggy-whiz
Number of posts : 9
Post  SteveCat Mon Feb 17 2014, 21:48
This is what I use, more accurate than the bike speedo and easier to install than an LCD unit.
Instrument panel upgrade Img_1410
Post  Cheshirecat Mon Feb 17 2014, 22:31
Where did u get that from Steve, is it a sat nav?
Cheshirecat
Cheshirecat
Number of posts : 498
Humour : Humour??
Post  SteveCat Tue Feb 18 2014, 09:00
Yes Kev, a Garmin 550 SatNav. It is one of the 'sub' screens which only works when it is in the bike mount - you can use the unit in a car and the mileage and fuel gauge are not affected.
Just a note on the fuel gauge - it does not reflect what is in the tank. For it to work you need to enter the tank range (only once) and to fill the bike up completely. I've only ever used it when my speedo breaks (happened a good few times with two 'Cats, hence the expectation for it to break again  Rolling Eyes ).
I do use the 'speedo', either in this screen if I don't need the map or a smaller speed display is shown with the map. I do like the digital display  Wink
