suspension
Tozcat
suspension
Hello folks after your vast experience and knowledge......past my test just over a year ago and wifey decided against allher better judgment I might add that she wants to go on the bike, what I need advice on is how to adjust suspension accordingly and what to and what tyre pressures are required...hoping to get to Thundersprint on sunday !!!!!!! thanks folks
Tozcat- 3Bronze
Number of posts : 23
Hobbies : Bikes, football, grandkids
Humour : All of above
Registration date : 2013-04-08
Re: suspension
Suspension wise you would normally only adjust the Preload on the rear to compensate.
Can't remember what the recommended tyre pressures are for pillion. Radar & Krusty have pillions regular, hopefully one of them will be able to help.
YZFJohn- 5Gold
Re: suspension
Tyre pressure 36 psi front and 42 psi rear - that for high speed and pillion.
Re: suspension
Thanks for that.....will give it a go
Tozcat- 3Bronze
Re: suspension
Wot Steve said
Re: suspension
After bouncing about all over the place on Wee Mac I think it might be worth me investigating my fairly recently serviced rear Hagon Shock.
£100 spent and I had Euan doing Zebedee impressions. When I first bought it approx £300 and 7-8 years ago I just got it fitted and never changed a thing.
Might need to resort to reading a manual......however any advice appreciated.
Alps trip next month and want to be as ready as possible.
Re: suspension
Before you ask!!!! No. Get it fixed NOW!!
Poor Euan looked
Like he was riding a pogo stick on the way back from WM.
Re: suspension
Still managed to stay in front of the Panigale though ...........until you overtook me.
Re: suspension
Rosco wrote:After bouncing about all over the place on Wee Mac I think it might be worth me investigating my fairly recently serviced rear Hagon Shock.
Sounds like the damping is too soft, Screw in the damper adjuster (just above the bottom yoke on the shock, it's a small allen screw) about 1/2 a turn clockwise and check the pre load nut is about 20mm down from the top most thread. Take the bike for a run and when you get back have some one hold the bike by the bars, and you go to the back and lift the rear of the bike by the grab handles, you should have at least 20mm of upward travel on the suspension(static sag is its correct term) Any adjustments of the damper should be made a little at a time until the bike feels right. Saying that I've never got my bike to feel good solo(Yamaha shock was better), but with further adjustment to the suspension it feels really good when riding hard with a pillion. Best of luck.
past-it- 6Silver
Re: suspension
i dont think its a setting unfortunately...wasn't like that on the saturday...i was behind you a few times on the saturday ride and didn't notice it, was very noticeable on the way home tho...
Re: suspension
Might need to sack fatty from being pillion.
Re: suspension
Cheers for your help Past-It.
I had a play with the damping adjuster and it certainly doesn't bounce back anywhere near as quick now.
Once I put my wheels on....fit a new chain and sprockets I'll try and get out and give it a whirl.
Fatty is allowed back on pillion.
He is threatening to join us on Big Mac.
