THUNDERCAT RADIATOR.
THUNDERCAT RADIATOR. Empty THUNDERCAT RADIATOR.
Post  yorkshireracer Tue Apr 03 2012, 20:32
Hi all,
I'm just starting to build a special based around a Thundercat motor in a Suzuki GS750 frame. I'm just in process of starting to source parts and I need a radiator/fan assembly.
Is there bits off any other Yam model that will be suitable just to increase my chances of finding anything suitable? Bearing in mind New Zealand is a total backwater for wreckers and I dont fancy cost of importing something.
Alternatively, can I fit more or less anything so long as radiator capacity is right?
yorkshireracer
yorkshireracer
Number of posts : 32
Registration date : 2012-04-03
THUNDERCAT RADIATOR. Empty Re: THUNDERCAT RADIATOR.
Post  Wooster Tue Apr 03 2012, 21:18
I'd be tempted to fit anything from a similar sized or larger bike.
Capacity is probably only half the issue, the other half (I suspect) would be flow.
Post  past-it Wed Apr 04 2012, 02:10
In England the Cats don't get hot anyway, so any 600cc plus rad should do the job.
Post  yorkshireracer Wed Apr 04 2012, 07:43
Cool, that helps. Temp here is much same as Blighty. Bike is going to be naked as well so would I get away without fan? Even if I have to go to a slightly larger radiator.
yorkshireracer
yorkshireracer
Post  Wooster Wed Apr 04 2012, 09:52
The fan does kick in in traffic and around city centres, so I'd probably fit one.
