Coolant/Antifreeze/Stuff that goes in teh radiator
Coolant/Antifreeze/Stuff that goes in teh radiator Empty Coolant/Antifreeze/Stuff that goes in teh radiator
Post  reciprocity Fri Sep 02 2011, 18:10
Just wondering if anyone has a recommendation for the mixture to put into the coolant bottle under teh seat. I noticed that mine was epic low the other day and realised I have no idea what I am to put in it. Does Halfords do anything worth buying or should I get it from amazon or another online establishment?
reciprocity
reciprocity
Number of posts : 116
Coolant/Antifreeze/Stuff that goes in teh radiator Empty Re: Coolant/Antifreeze/Stuff that goes in teh radiator
Post  yamahamad Fri Sep 02 2011, 18:19
You need ethylene glycol antifreeze mixed 50/50 with water unless it is ready mixed. The max Mark on the coolant reservoir is probably half way down the tank allowing for expansion.
Post  bobh Fri Sep 02 2011, 23:21
Castrol, and others, do motorcycle-specific ready-mixed coolants, available from many bike dealers. The Castrol one is straw yellow, others may be blue, but I think they are all compatible.
Alternatively, a local motor factor recommended some pink "long life" antifreeze which he said is the latest spec being used in VW's etc. and last a minimum of 5 years. This needed diluting 50/50 with deionised water, available from the same source.
