Air system
Air system
Does anyone have a drawing or photos, in regards to the air system?
I don't mean the main big pipes into the air filter box.
There's two air box's at the front by the ram air inlet, and there's a hose, I think it's only a drain, but I've followed it and there's another hose connect to it that apparently leads to nowhere. Could go with a diagram showing all the relevant pipes, of anyone had anything.
Jam
Jam
JAM- 1Silver
Number of posts : 111
Re: Air system
According to Mr Haynes; There are two hoses connected to the air filter housing. One is the crankcase breather, the other is a drain hose. the CB hose fits at the rear top centre of the box, between carbs 2 & 3. the drain is on the bottom corner near carb 1.
I hope this helps. Rich.
» shock to the system/or HOW MUCH!!!!!
» marker system
» Ventura luggage system??
» Marker (Drop Off) System
» Rideout 'Drop off' Marker system
» marker system
