rev counter diagnosis
shock rev counter diagnosis
Post  Dave Sun Jan 23 2011, 17:13
Hi guys
Can anyone help.Took the cat out for a ride today,went well until i stopped for a pit stop.Bike then refused to start,we bumped it and it ran fine but the rev counter kept going from 0 to 8 then down to 3 then 0. It just kept repeating these codes. It now won't start. I know its trying to tell me something but I can't find a list of codes. I've looked in the Haynes manual but unless I'm missing something I can't find any.
any ideas Dave
Dave
Dave
Number of posts : 8
Humour : dark n disturbed
Registration date : 2009-05-21
shock Re: rev counter diagnosis
Post  stretchie_ Sun Jan 23 2011, 17:37
Alright Dave
You got an owners manual cos it's in there.
One is definitely fuel sensor related. You had the tank off recently and didn't plug the wires back together or just not quite enough, and the other I think is something to do with the throttle??
Post  Dave Sun Jan 23 2011, 17:53
yeah i've just found some info on another site.something that calls itself tps. but why is it not starting. once i bumped it it ran fine.
Dave
Dave
Number of posts : 8
Post  Mac jock Sun Jan 23 2011, 18:08
Tps is the throttle position sensor ( the 3,000rpm fault)
If this is faulty the ecu could be altering the ignition to suit the fueling it's expecting. Try starting with a light twist and see if that helps.
The 8,000 rpm is saying that there's an issue with the reserve light on the fuel tank
Sorry if I'm telling folk how to suck eggs
Mac jock
Mac jock
Number of posts : 32
Hobbies : Track Engineer
Humour : Dark
Registration date : 2011-01-21
Post  weasley Sun Jan 23 2011, 18:19
Also discussed here.
Post  Dave Tue Jan 25 2011, 20:05
Hi Guys
Thanks for your posts.It turned out to be electrical.I cleaned all the connections on the earth side and that seems to have sorted it.
I knew it was not fuel since I took the tank off just before last summer,gave her a service, and we spent a great summer terrorising the good people of Wales she never missed a beat.
Dave
Dave
Dave
Number of posts : 8
Post  stretchie_ Wed Jan 26 2011, 00:00
Cool, we like fixes like that
Post  martintaff Sat Feb 19 2011, 03:41
i had the same problem which has been sorted . but now the revs wont go back down as quickly as id like ,i balanced them as close as i could but im not happy .its done 40 thou now so i bought another set of carbs on ebay ,will fit them soon and see what happens .
martintaff
martintaff
Hobbies : porter /enduro / rugby.
Registration date : 2010-11-27
Post  stretchie_ Sun Feb 20 2011, 20:37
Alright, if the revs aren't dropping back as well and you've balanced them you might need to adjust the pilot screw/mix screw.
I've just been though the same today with the missus Ninja, adjusted the mix screws and it's bang on now.
