Error codes.....Can we have a Sticky???
supraloopy
sir digby
seancat
Hi,
Could someone please make a sticky for all the known rev counter errors??
As I think I might have one.....I think Ive been a bit of a twit and done something which maybe the cause, but Im not sure?
I removed the return cable on the throttle yesterday as it was frayed (New one coming from ebay as I speak) this was causing throttle return to drag and sometimes stick.....simple.
But, I went for a short ride on it today thinking that it should be OK without the return cable attached, as Ive done this to various bikes with no problems (In fact, it was better as the throttle snaps shut, way faster than if the cable was there)
BUT.......As I was riding I noticed that the rev counter dropped to zero for a few seconds, then went back up to the correct rev speed. I noticed that the bike was a little bit jerky as the revs came back. This happened at least 5 or 6 times in a 20min run. I basically came home because I thought it might be dangerous?
Now, Im thinking that because Ive removed the return cable, the throttle sensor is going hay wire because the tension on the cable now varies, and the slack is not being taken up....
Am I correct in this thinking??? (I think when I started it yesterday that I got an error code on the rev counter. I cant be sure but I think it went up to 8000 rpm, then back to zero. Didnt pay much attention to the rev counter, so I only caught it dropping)
Thoughts, answers general piss taking welcome!
Thanks,
Sean.
Thanks,
Sean.
seancat- 2Silver
Number of posts : 152
Hobbies : Designer
Re: Error codes.....Can we have a Sticky???
If you had the fuel tank off its worth checking the wiring connectors under the tank, especcially the fuel light sendor wire (is it a green connector from recollection?)
robertcains wrote:If you had the fuel tank off its worth checking the wiring connectors under the tank, especcially the fuel light sendor wire (is it a green connector from recollection?)
Hi Robert,
Yes, its green (which fits into a clear/white female).
Yes, I connected it back up and did a visual check of the breather, and the fuel hose and clip.
All are attached correctly.
I did notice a bit of white residue on the green connector. Could it be worth cleaning this up?
Although it was all OK before I had taken it to bits!
Sean.
seancat- 2Silver
Hobbies : Designer
Definitely worth eliminating with a drop of WD40 Sean
My manual says there are only two error codes for the Cat:
3000rpm - throttle position sensor
8000rpm - fuel indicator light
petercriss wrote:My manual says there are only two error codes for the Cat:
I second Peters posting. I have the User Manual and Service Manual in PDF. I can place them in one of our web servers and send you the links if you like so you can download.
John.
YZFJohn- 5Gold
Hi Peter, Hi John,
Thanks for the reply.
I wasn't sure how many codes there actually was.
Thanks for letting me know that there are only the two.
John, yes that would be great if you could post the links. I could do with them both.
Thanks for the answers guys, much appreciated.
Sean.
Sean.
seancat- 2Silver
Hobbies : Designer
Here you go Sean. If I have written the new download script right you should be able to click on each link to download the pdf. The Full Service Manual will take a while it is 65Mb.
YZF600R Owner Manual
YZF600R Full Service Manual
YZF600R Suspension Setup
John.
YZFJohn- 5Gold
Thanks John,
VERY handy!!!
:whoop:
VERY handy!!!
:whoop:
seancat- 2Silver
Hobbies : Designer
No worries, glad I could help.
John
YZFJohn- 5Gold
my bike did that a few times when i first got it , sounds stupid but, is the battery conections done up tight ? thats what i think caused mine , same symtoms and thats all i did and has been fine ever since
Holy Thread revival supraloopy!
Although I would be interested in these manuals too if anyone can help out.
stevemcc- 2Silver
Number of posts : 192
Hobbies : Aviation Engineer
dident check the date , thanks steve , just realised i gave advice to a post made in july
Hello,
sorry to revive the tread but i have a cat and i getting this Revs code really often.
First i thought it was some problem with the clutch, but luckily i found this forum \o/ .
So i have the Haynes Manuals, can i find how to fix those error there?
Seancat, how could you fix yours?
vinisuarez- New Member
Number of posts : 3
Registration date : 2013-06-11
Hello, welcome.
What number does the needle go to and then return?
Hey thanks for the answer.
It was going for both, but i found in another post that this could be because of the nut on the battery not tight enough.
And it was my problem, fixed yesterday and went for a big ride, and for now everything is ok back :cheers:
Thanks anyway
Thanks anyway
Number of posts : 3
Glad you got it fixed. Would you like to pop by the New members area and say hi there and we can all welcome you?
Tee-Forty- 3Silver
