Cable lubing
Cable lubing
Reckon I should lube up the throttle cables in the near future (and prob the clutch while I'm at it). It's been many a year since I did this and I'm pretty certain I used to just disconnect them at the top, tie a little bag round, put a bit of engine oil in and hang em up for a bit until I assumed they were lubed all the way down.
Any suggestions/improvements etc would be appreciated
I've never used cable lube and one of those things you fasten on the end to apply it, btw
Re: Cable lubing
Sounds a real good way of lubing them but a bit of messing around disconnecting them unless you are stripping down to do something else. I just give them a squirt of wd40 now & again with the straw & have not had a problem.
Re: Cable lubing
http://cgi.ebay.co.uk/Cable-Oiler_W0QQitemZ170464485724QQcmdZViewItemQQptZUK_Motorcycle_Parts?hash=item27b079a15c
Spray some WD40 down it till it runs clear , then drip some oil down the cable, and HAY PRESTO it will run very smooth
Also it make's it a lot easier on the wrist when operateing the clutch
Davie
Davie
furball- 3Gold
Re: Cable lubing
Thanks for the link Davie, just bought one - can't stand the pain in my left hand anymore from a stiff cable (even though its supposed to have be done at the last service).
-Steve
-Steve
Re: Cable lubing
Some WD40 sounds like a good idea.
Thanks for the help
(anything to ease the strain on my right wrist)
Thanks for the help
Re: Cable lubing
petercriss wrote:(anything to ease the strain on my right wrist)
Might be more than just the throttle causing that strain though, could be putting a little to much weight on your wrist ...
» speedo cable probs
» speedo cable
» Speedo cable ends
» speedo cable replacement
» Speedo Cable thingy
» speedo cable
» Speedo cable ends
