Speedo Cable thingy
Speedo Cable thingy
Hi all
My speedo cable snapped about a year ago and I duely got it replaced and thought nothing more of it. However, last weekend part way through a ride out the speedo stopped working, undid the nut and found its snapped again.
I realise that things like this happen but was wondering if its something to do with my style of riding ? being a relative newbie then I wondered if the life of the cable gets "cut" short because of harsh acceleration or some other rider related problem rather than a bike related one? Is that right or possible or just one of those unlucky things ? What's the average life of a speedo cable on a cat ?
Any help anyone can give would be gratefully received :-)
Thanks very much
Thanks very much
biscut- 3Silver
Number of posts : 217
Hobbies : IT Geek
Humour : dark and perverted
Registration date : 2012-09-20
zuluzulu likes this post
Re: Speedo Cable thingy
No, riding style will not affect speedo cable life. It could be that something is not quite aligned as it should be, or just one of those things.
Could be the style of riding
I'm a past master at speedo problems, but never a broken cable, been through a number of items in the hub, have done a fair number of miles on 'Cats though.
Sounds a bit like routing of the cable could be the cause.
Hi Weasley
I did wonder as my 0-60 time is now 1.6 seconds :-D (kidding)
Stevecat, thanks for that, will have a look at the weekend and see if anything weird is going on routing wise. It's the bottom section that has broken again a few inches up from the wheel, could it be something to do with the hub as that got replaced at the same time as the cable last time as that was broken too ?
biscut- 3Silver
Hobbies : IT Geek
After breaking one I followed advice I got and after routing the replacement cable I dripped some oil down the cable till it seeps from the other end and the greased up both ends before final fitting.
Still going strong after 10's of thousands miles since (touchwood)
Good luck
Good luck
As above really, if correct routing and lubing doesn't work..... I'll wash my bike
The Official Yamaha workshop manual has cable routing diagrams and will show you where it is supposed to go, not sure the Haynes manual does though.
If you don't have the Workshop manual, I think there is a download link somewhere on here, OR Google is your friend 'YZF600R Service manual' also 'Carl Salter' and 'Repair Manual Club' come to mind as a possible source. Unfortunately I have moved house and job and laptops so I cannot get to my manuals otherwise I'd help you out with a screen shot
Thankyou both for the advice, will definitely check cable routing at the weekend.
biscut- 3Silver
Hobbies : IT Geek
Wanted to say thank you for the helpful advice peeps have given me.
Replaced the cable, lubed it till it was dripping and all seems to be working again, lot easier to do than I thought it would be. Did notice that the cable wasn't fastened into the cable guides on the inner fairing so could that cause problems long term ? If not then I am at a loss as to what has caused it to break after such a relatively short time. Anyway, all fixed just in time to be packed away for winter LOL.
Thanks again everyone
biscut
biscut
biscut- 3Silver
Hobbies : IT Geek
Result.
Awesome,
» speedo cable
» Speedo cable ends
» speedo cable probs
» speedo cable replacement
» finally got some pics up.
» Speedo cable ends
