Rear brake disc
Rear brake disc Empty Rear brake disc
Post  fri68683361 Wed Oct 05 2016, 20:23
Does anybody have a decent rear brake disc I can have?
fri68683361
fri68683361
Number of posts : 66
Registration date : 2016-08-06
Rear brake disc Empty Re: Rear brake disc
Post  The White One Wed Oct 05 2016, 20:32
I've been looking on here but was there not a post regards compatible parts for the cat. Wondering what other discs would fit the rear on a cat.
The White One
The White One
Post  bobh Thu Oct 13 2016, 22:13
When I'm looking for compatibility of parts between models, I normally refer to either [You must be registered and logged in to see this link.] or [You must be registered and logged in to see this link.] (US).
Unfortunately neither site seems to show any other Yamaha models that use the same rear disc as the Thundercat (part no. 4JH 2582W 00 00), though the part no. on the A J Sutton site for the FZS600 Fazer is the same as the Thundercat one except from the last "00" so it might be worth a punt if you can find a cheap one.
The American site obviously only lists models that were imported to the US, and without looking through every year in detail, it doesn't seem that the FZS600 was among them.
I have a few spare discs kicking around in the shed, so if you can let me have the disc diameter, plus the no. of bolt holes and their p.c.d., I'll have a look to see if there's anything that might fit.
Post  fri68683361 Fri Oct 14 2016, 11:05
Thanks bud iv managed to get a cheap thunder ace disc off eBay that is the exact same apart from a slight difference in thickness.
I do need some bolts for it, if you have any kicking around?
fri68683361
fri68683361
Post  bobh Fri Oct 14 2016, 23:27
Sorry, I might be able to find one or two rather manky ones, but not a complete set.
Post  fri68683361 Sat Oct 15 2016, 11:04
That's alright mate don't worry about it Smile I'm sure I can get a set off the Internet cheap enough
fri68683361
fri68683361
