Speedohealer v4
Speedohealer v4
Juse been giving the new bike a proper going over and I've found something underwhelming seat called a speedohealer v4?
I've Googled it and it seems to be some kind of electronic correction kit to make sure the romantic and speed is displayed properly.
Any idea why it might be on there?
Only thing I can think off is if the gearing has been changed?
Re: Speedohealer v4
Autocorrect is brilliant.
healtech-electronics.com wrote:
On most modern motorcycles factory speedometer over-reading could be as high as 10%. So even a modest gearing change can have the speedometer off by 15%. Changing the sprockets will also result in higher odometer reading, decreasing resale value without valid reasons. The SpeedoHealer is an inexpensive, convenient and very simple way to sort these speedo and odo issues. Compatible with all motorcycles with non cable driven speedometer. Get your fix today – You won’t find any better alternative on the market! The SpeedoHealer is the most popular and reliable calibrator in the world – acknowledged by thousands of happy customers worldwide.
Note: The SpeedoHealer can also be used to remove the top speed limiter on certain vehicles for racing purposes, including: CBR1000RR, VFR800X, VFR1200F, ZX-10R, ZX-12R, ZX-14, FZ-09, MT-09, R1, V-Max, Can-Am ATVs and many more.
Re: Speedohealer v4
Could be a change of gearing, change of wheel/tyre size or even a foreign import with a km/h speedo. Probably the first one.
Re: Speedohealer v4
Isn't the Thundercat's Speedo (and Tacho), cable drivenWooster wrote:Autocorrect is brilliant.healtech-electronics.com wrote:
So if this is an electronic widget to calibrate an electronic whizzbit . . . isn't this wajamacallit going to be a redundant tweakabite
Sorry for the use of all that technical jargon there
Re: Speedohealer v4
Speedo is cable, tacho is electric as far as I remember. have to admit I was mystified by this gizmo on the 'Cat, sounds something that would go well on the Tracer.
Re: Speedohealer v4
He's riding a FZ1 now
..it baffled me initially as well, until I remembered about the new bike.
Re: Speedohealer v4
yes, you right, I really ought to keep up, sorry
Re: Speedohealer v4
I would apologise for the confusion had I not started this thread with 'Just been giving the NEW bike a once over' haha
See this is why I'm sticking around. You lot provide the comedy as well as the help
Re: Speedohealer v4
dudeofrude wrote:I would apologise for the confusion had I not started this thread with 'Just been giving the NEW bike a once over' haha
At your service sir
