Just arrived
kwakkat
The White One
swagmanz
Just arrived Empty Just arrived
Post  swagmanz Fri Apr 29 2016, 17:36
Hi all
My name is Keith I am from Lincolnshire I have just got the Cat as a winter bike, I also have a 2003 fazer1000, have a couple of problems with the Cat at the moment as it has been stood for a large part of the last 10 years, goes fine when opened up but on tick over it is a little lumpy I suspect slow running jets are gummed up, and the other problem is the rocker cover gasket is leaking, mileage is 23000.
swagmanz
swagmanz
Number of posts : 6
Registration date : 2016-04-28
Just arrived Empty Re: Just arrived
Post  SteveCat Fri Apr 29 2016, 17:41
Hi Keith, welcome.  Does sound like the jets need cleaning.
That gasket part isn't number 4TV-11193-00 by any chance? I've got one going for not too much moola Wink
Post  swagmanz Fri Apr 29 2016, 17:50
Thanks for the welcome Steve and the offer of the gasket but I already have one thanks but if I ruin it I'll be in touch Keith.
swagmanz
swagmanz
Number of posts : 6
Post  The White One Sat Apr 30 2016, 09:16
swagmanz wrote:Hi all
Shouldn't be any reason for it to leak unless its been battered about when taken off or just not fitted properly.
Just to be on the safe side check the cover and head for warpage when you have the cover off.
The White One
The White One
Post  yamahamad Mon May 02 2016, 10:38
Hey & welcome. The idle issue is most likely blocked idle jets. The rocker cover gaskets don't really leak unless it's been off a few times or been damaged while removed, if the air filter has been cleaned & re oiled a bit of excess oil can drip out of the air box water drain holes when it gets hot in use. It drips onto the rocker cover & looks as though the gasket is weeping.
Post  swagmanz Mon May 02 2016, 18:36
Hi thanks for the info will check out for warping of head and cover, it must be a leak as it got onto my left boot while riding it to test the other day so has got worse in the last week, will have a good look this week sometime when it stops raining (no garage here).
swagmanz
swagmanz
Number of posts : 6
Post  kwakkat Tue May 03 2016, 15:07
hi & welcome now leave me alone i,m a grumpy old fart violet-lol
kwakkat
kwakkat
Post  swagmanz Tue May 03 2016, 15:19
Yeah me too!!!! Very Happy
swagmanz
swagmanz
Number of posts : 6
Post  dudeofrude Wed May 04 2016, 19:12
Hey Keith. Welcome to the forum. Where abouts in lincs are you? I'm up in not so sunny cleethorpes
Number of posts : 426
Hobbies : Gym, Tattoos, Ps4
Humour : Sick, Sarcastic
Post  0ldcat Thu May 05 2016, 22:58
Hi Keith , and Welcome to the forum left thumb up
Post  yamrdtez Fri May 06 2016, 21:15
welcome buddy
yamrdtez
yamrdtez
Number of posts : 119
Registration date : 2016-03-17
Post  swagmanz Fri Jun 10 2016, 17:47
dudeofrude wrote:Hey Keith. Welcome to the forum. Where abouts in lincs are you? I'm up in not so sunny cleethorpes
Hi dudeofrude I am just outside Lincoln at Torksey lock mate.
swagmanz
swagmanz
Number of posts : 6
Post  swagmanz Fri Jun 10 2016, 17:52
Well guys thanks to you all for the welcome, I have sorted the leaking rocker cover gasket, had the carbs ultrasonically cleaned and balanced, but I still have a problem with the revs hanging around 3000 for a few seconds very disconcerting when you are approaching a bend and going down the box, I hate having to use the brakes to slow down.
swagmanz
swagmanz
Number of posts : 6
Post  Rosco Tue Jun 14 2016, 17:42
Sorry I'm late - Welcome aboard Keith.
Post  greencat Tue Jun 14 2016, 19:49
Welcome to the site Keith.
There are a few of us in Lincolnshire. I'm up nr Brigg, but work in Gainsborough so not far away. We should have a local meet sometime.
Glad to hear you're getting the bike sorted. You'll be in time for the Lincolnshire rideout! Maybe you could join us.
Cheers, Chris
Post  ellie Tue Jun 14 2016, 23:03
Hi & welcome to the site - from a fellow Lincolnshire yellow belly x
