Loose controls
Loose controls Empty Loose controls
Post  dudeofrude Wed Mar 30 2016, 10:25
Just wondering if anyone else has this problem? My indicator/horn/choke control is really loose on my bar. I've tried tightening it but just doesn't seem to want to grip the bar?
It's a minor annoyance but everytime I used the choke lever it changes the position of the indicators.
Can't think of a way to keep it in place?
Number of posts : 426
Hobbies : Gym, Tattoos, Ps4
Humour : Sick, Sarcastic
Loose controls Empty Re: Loose controls
Post  0ldcat Wed Mar 30 2016, 14:20
Have you tried packing out the space between the bar and the control(s) with say a strip of rubber (an old cut up cycle inner-tube would be ideal), and then re tighten the control onto the packed out bar.
Just an idea . . . I'm leavin' Loose controls Exit-d10 green smile
Toff
Post  dudeofrude Wed Mar 30 2016, 16:01
I have actually tried a few things in there to try and shim it up but nothing seems to be working. I'd not thought of an inner tube though to be fair so might give that a go haha
Post  FatCat Wed Mar 30 2016, 19:05
Inner tube is a good idea. If it doesn't need something quite that thick, then perhaps some insulating tape around the bar where the switch block goes.
FatCat
FatCat
Number of posts : 429
Post  Catnapper Fri Apr 01 2016, 16:17
Or emery cloth, grit side down
Catnapper
Catnapper
Number of posts : 365
Hobbies : Motoring, DIY
Post  S4MRE Wed Apr 06 2016, 22:53
Best way to stop the problem all together is to drill and tap a hole in the bottom of the control and put in a grub screw,
But once you have drilled the control the best thing to do is to line it up were to will want it to finally sit and run the drill through again and put a small dent in were you would like to centre the grub screw on the handle bar so it doesn't slip
S4MRE
S4MRE
New Member
New Member
Number of posts : 2
Hobbies : Bikes
Humour : Different
Registration date : 2016-03-13
Post  dudeofrude Wed Apr 06 2016, 22:56
Great idea, thanks S4mbre
Post  Wooster Wed Apr 06 2016, 23:07
Catnapper wrote:Or emery cloth, grit side down
My first thought also...Wet&Dry. Very Happy
