Hi from Bournemouth
+5
bat-kam
9 posters
Hi from Bournemouth Empty Hi from Bournemouth
Post  bat-kam Mon May 11 2015, 19:41
Hi all
I have bought my '97 Cat at the beginning of April. Stripped it down, cleaned, painted swing arm and done few other jobs. Once i adjusted the "soft" suspension it feels ok now. Although moving to Cat from 2011 750 GSXR it feels a bit too soft.
So far I am loving this bike and I hope i will use your knowledge and experience to further enhance my bike as I try to do most of the work myself.
Next thing on the list is to sort out the jittery low revs the riding slow. Between 1,5k - 2,5k rpm. Could it be becuse crbs need clening and/or syncing?
Bike has done 24k miles and there is some history but I can't tell if it had the valve clearence checked or carbs synced.
Once again HI
Kam
bat-kam
bat-kam
5Bronze
5Bronze
Number of posts : 41
Registration date : 2015-05-11
Hi from Bournemouth Empty Re: Hi from Bournemouth
Post  Roll The Bones Mon May 11 2015, 19:53
welcom2ytc
Post  Rosco Mon May 11 2015, 21:21
Hi & Welcome Kam.
Balancing the carbs is fairly straight forward and you can make yourself a cheap manometer if you don't have or can't borrow any gauges.
Good luck & Enjoy.
Post  SteveCat Mon May 11 2015, 21:22
Hi and welcome.
Might be an idea to post the low revs, could be normal, could be out of balance .... They don't run quite the same as a newer bike, in the lower revs the carbs are using the idle jets and go onto the mains from about 2.5k. I had an issue with my second 'Cat, never idled properly - yammy dealer who did my p/x said it was the carbs, could be mixtures, well it seemed to be in my case.
Post  bat-kam Mon May 11 2015, 22:02
Thx
I will be taking her to local garage for strip, clean and balance. I don't have the carbtune or similar
If i did have one though would I need some extra tools? On facebook some mechanic mentioned something about choke locking tool.
Any good writeups here how to balance DIY?
bat-kam
bat-kam
5Bronze
5Bronze
Post  0ldcat Tue May 12 2015, 00:28
welcome mc
To the forum great
Post  mrfrance Tue May 12 2015, 08:21
Hello and welcome!
There are a number of different vaccuum guages you can buy, I think I paid around £40 for a set of 4 guages. It's a really simple job to do on the cat, you don't need any other tools except may an auxillary tank (which you could make) to feed fuel whilst you've got the tank off.
Another solution would be to chuck through some additive as there could be a blockage in the jets, especially if the bike has been sat around with old fuel inside. I use "non-commercialised" stuff like Forte gas cleaner or Seafoam - this stuff really cleaned out my thunderace, as some of the guys on here will remember how dirty that thing was.
A garage might charge you a couple hours labour for balancing carbs when it really is only a 20minute job (including taking tank off) and is something you should maintain every big service so might be worth investing in a set of gauges, or as Rosco said you can make one relatively cheap - you'll have pick at him for that info as I have no idea how!
Alternatively, I'm not a million miles from you, so you're welcome to pop round and use my gauges and I can walk you through it.
Post  SteveCat Tue May 12 2015, 09:19
bat-kam wrote:On facebook some mechanic mentioned something about choke locking tool.
That'll probably be a YICS blanking tool, I think you'll only find that being used in some Yamaha Auth workshops. I've not seen one of those for quite a few years. I doubt any 'Cat here has had the carbs adjusted with that.
Post  bat-kam Tue May 12 2015, 14:48
I have agreed with a local garage that they will clean and balance my carbs for £120 all in. All I will have to do is to leave the bike on Wdnesday and take their loan bike until Friday afternoon. This way they will be able to fit my job inbetween all other
In the future I may buy a set of CARBTUNE and do it myself. How often does it need adjusting?
bat-kam
bat-kam
5Bronze
5Bronze
Post  SteveCat Tue May 12 2015, 16:19
The vacuum pipes are conveniently placed on the frame, so a quick check can be performed without too much of a problem, probably check every few thou - not that I ever did that with mine, once a year or second year!
Post  mrfrance Tue May 12 2015, 16:26
I'd be interested to know what they will be doing when they clean the carbs. If they are taking them apart and cleaning them out, then that's not a bad price with the loan bike included. If they are just taking of the tops of the carbs and spraying stuff in, then it's not a good price!
Anyway, best of luck!
Post  SteveCat Tue May 12 2015, 16:32
Oh I forgot to say, whilst they are cleaning the carbs get them to check the TPS, it might need adjusting - that might be contributing to the low revs being rough.
The values and the calculation are in the workshop manual (Haynes and Yamaha, although the latter has an error in the example!)
Post  Jkillroe Tue May 12 2015, 23:47
Hello and welcome
Jkillroe
Jkillroe
Number of posts : 176
Registration date : 2014-07-23
Post  Catnapper Wed May 13 2015, 09:05
Welcome aboard!!
Just a quick question. When balancing my cards should I disconnect the scottoiler or leave it connected as this is how the bike runs day to day
Catnapper
Catnapper
Number of posts : 365
Hobbies : Motoring, DIY
Post  0ldcat Wed May 13 2015, 19:13
Hi from Bournemouth House+of+Cards Don't think your Scottoiler is gonna make a jot of difference to card balancing chap pmsl violet-lol
Post  FatCat Wed May 13 2015, 20:48
Welcome to the forum welcome3
FatCat
FatCat
Number of posts : 429
Post  Catnapper Wed May 13 2015, 21:26
Bleeping predictive text
Catnapper
Catnapper
Post  SteveCat Wed May 13 2015, 21:32
I'd say if the Scottoiler is in line with the balancing pipes leave it in.
Post  bat-kam Fri May 15 2015, 09:45
I picked up my bike from Motorcycle Trade-Ins in Bournemouth this morning. It had full carb strip and clean and sync.
I have to say that £120 was money well spent. It has made BIG difference to low rev range. Just want I wanted. One thing I will have to adjust is the throtle free play as it is too loose for my liking.
The comments from mechanic was that the carbs weren't that dirty but very out of balance.
Going forward I will invest in CARBTUNE or similar and do the sync once every 6 months.
Kam
bat-kam
bat-kam
5Bronze
5Bronze
