satnav mobile holder
how do you think. Will that be easy to fit on thundercat? ?
Re: satnav mobile holder
Looks quite simple but how often does that turn in to a pain in the arse job. Looks pretty good quality though. I've been considering one of these so I can have a digital speedo.
ryan.moyles- 3Bronze
Number of posts : 20
Registration date : 2015-04-05
Should be quite straight forward.
Sorry I changed your link.
I have something similar - yes it was straightforward.
Although I think that's the wrong fork stem diameter - mine was a 15-17mm part.
FatCat- 7Silver
Number of posts : 429
I was on the Phone so I didn't see anything wrong with link.
Thx for changing that.
hot to fit tha. In if there is no any holes?
I used one of these to replace the existing top yoke nut and leave access to the hollow tube to fit the Sat Nav mount.
Also - make sure you've read the edit in my post above - the holder you linked to is the wrong diameter to fit in the cat's top yoke.
FatCat- 7Silver
So you know what size do I need.
Can you advice me exactly what size of l nut and what size of things for holder. Hard for me I am IT not mechanic. I post linkt for holder but there is 20 diferend sizes
To fit - you just need a top yoke nut with a hole in the centre like this one.
then you need a RAM mount that is slightly smaller than the internal diameter of the yoke tube. It's in two halves that are cut at an angle so when they two halves are pulled together they splay apart and 'jam' in the inside of the fork stem. For the Thundercat the size that I got was 15-17mm.
Just loosen this off and then pop it into the fork stem tube and tighten up the allen bolt with a suitable key/bit.
The just fit the case and tighten it up - ready to go. 2 minute job.
Regards Ian
Regards Ian
FatCat- 7Silver
FatCat where did you get that 15-17.2 Fork Stem Yoke Motorcycle Mount -
I used one of these - the do others with different case sizes with 15-17mm mounts if you have a different phone/satnav.
FatCat- 7Silver
thx for help. Order done now just need to wait
» Mobile phone holder
» GPS , SATNAV
» RiDE Reveiw of Bike SatNav's
» UK Mobile Phone Directory
» Anyone know any good mobile valets?
» GPS , SATNAV
