Wanted - Clutch Lever Pivot Bolt Bushing.
Wanted - Clutch Lever Pivot Bolt Bushing. Empty Wanted - Clutch Lever Pivot Bolt Bushing.
Post  Tee-Forty Mon Jan 26 2015, 03:46
As you can see, that Chinese bushing that fits around the pivot bolt is much too large. I'm after a yamaha one, please.
Size: 10mm diameter with a 6mm bore.
Thank you.
Tee-Forty
Tee-Forty
Wanted - Clutch Lever Pivot Bolt Bushing. Empty Re: Wanted - Clutch Lever Pivot Bolt Bushing.
Post  FatCat Mon Jan 26 2015, 15:41
You could give these guys a call as they don't seem to do that size.
Or, alternatively use two bushes (a 6mmx8mm inside a 8mmx10mm).
Good luck!
FatCat
FatCat
Number of posts : 429
Post  Tee-Forty Tue Jan 27 2015, 03:32
Thanks for the link, FatCat.
I'm going to have another search in my box of oddments, I might find an old lever that has one.
Edit: 04 Feb' 2015.
Couldn't find one in my box of bits, so I'll order a new one from Mr Yamaha.
Part No. 31A-83913-00
Tee-Forty
Tee-Forty
