Egg Sucking..
Egg Sucking..
Good job we're all daft enough to have to listen to Confused.coms' flood advise............
With a high number of flood warnings in force across England and Wales - and with more extreme weather conditions forecast - householders will be battening down the hatches in a bid to protect their homes. However, it’s not just your property that is at risk if flooding does strike, as your vehicle could be prone to getting damaged too.
Flood damage can be costly
Repairs to flood-damaged motorbikes are often expensive, with many vehicles being written off for health and safety reasons. Even a small amount of water can cause a significant amount of damage to your engine - and this damage can take months to show itself as corrosion causes mechanical parts to fail.
With the number of flood warnings continuing to rise, bikers must ensure they understand how to avoid flood water damage.
Top flood tips for motorbike owners
Visit the Environment Agency’s website before you start your journey to check for flood warnings.
If you are aware of a flood warning in an area where your motorbike is parked, move it to higher ground.
As well as the risk of damage to your vehicle by leaving it in a flooded area, it may also be a hazard or cause an obstruction to emergency services.
Adjust your route to avoid any roads that are prone to flooding during periods of heavy rain.
If you have to drive through a flooded area, take care. Do not attempt to drive through water if you are unsure of the depth.
Test your brakes as soon as you can after driving through water.
Carry a fully-charged mobile phone with you so you can request help if you break down.
If your bike has been in a flooded area for a prolonged period, get it checked out at the earliest opportunity.
Made me giggle....
Made me giggle....
Re: Egg Sucking..
And when moving said motorcycle to a safe place make sure you don't cause any damage to it yourself
Re: Egg Sucking..
Do they get the dreaded lurgy from flood water?ellie wrote: with many vehicles being written off for health and safety reasons.
Wonder what they'd make of this guy riding his bike through 'some' waterellie wrote:Do not attempt to drive through water if you are unsure of the depth.
Re: Egg Sucking..
Blimey! I've been riding through some deep water to work... but that is just madness nice adaptation to the air flow though, good idea!
Re: Egg Sucking..
I'd be thinking twice about doing that in my LandRover let alone on the bike
