Bike Preparation
Tom...
randomeclipse
Bike Preparation Empty Bike Preparation
Post  randomeclipse Sat Dec 21 2013, 20:33
Hey guys,
Haven't ridden the bike for a month or so and have decided to tuck her up until the new year, therefore I was wondering what key things I should do if I know she's going to be dormant for 3 - 6 months? I'm guessing:
- Remove the battery and store it @ room temperature?
- Fill the tank up to full?
- lube up the chain and wd40 bits like brake levers etc?
Sorry, am a tad new to bike ownership and have only had my license 5 months Smile
randomeclipse
randomeclipse
Number of posts : 39
Hobbies : Network Engineer/Football, the Fiancee & Bikes :)
Humour : Sarcasm, it's the highest form of intelligence
Registration date : 2013-08-05
http://www.afkish.blogspot.com
Bike Preparation Empty Re: Bike Preparation
Post  Tom... Sat Dec 21 2013, 21:39
Personally I would turn off the fuel and run the carbs dry. Makes re-starting easy and prevents the idle jets bunging up so much. Clean everything and I like to coat everything in ACF 50. Maybe stick the battery on an optimiser too. I'm sure other, more qualified bodies will be along soon to say similar stuff.
Tom...
Tom...
6Bronze
6Bronze
Number of posts : 52
Post  randomeclipse Sat Dec 21 2013, 21:48
./pulls out the Haynes! Smile
randomeclipse
randomeclipse
Post  Tom... Sat Dec 21 2013, 22:00
I don't know how other 'cats respond, but mine is a c**t to start after standing for a few weeks, and even then the revs are lumpy. Eurgh! Haha!
Tom...
Tom...
6Bronze
6Bronze
Post  randomeclipse Sun Dec 22 2013, 00:03
Hmm, mines a 2002 model, can't seem to find the fuel pump valve (is it a valve?! :p) in the manual.
Hmm.
randomeclipse
randomeclipse
Post  randomeclipse Sun Dec 22 2013, 00:04
Tom... wrote:I don't know how other 'cats respond, but mine is a c**t to start after standing for a few weeks, and even then the revs are lumpy. Eurgh! Haha!
Same here, I tend to leave it to warm up for 20 minutes before setting off and even then it takes a little while to warm up. Cold little thing Smile
randomeclipse
randomeclipse
Post  Tom... Sun Dec 22 2013, 00:26
Fuel pump doesn't have a valve, it's the stopcock under the tank, son of a whatsit to find without removing the tank, but it IS possible without if you practice! Haha!
Tom...
Tom...
6Bronze
6Bronze
Post  randomeclipse Sun Dec 22 2013, 12:38
Tom... wrote:Fuel pump doesn't have a valve, it's the stopcock under the tank, son of a whatsit to find without removing the tank, but it IS possible without if you practice! Haha!
Oh bugger, and I bet you need the hands of a 5 year old girl to get to it too!
randomeclipse
randomeclipse
Post  SteveCat Sun Dec 22 2013, 13:16
Remove the seat, undo the bolt holding the tank, lift the tank up about 6". Look for the fuel pipe from the tank, feel along it till you get to the tap. the lever is pointing downwards, turn it from 6 o' clock to 9 o' clock, in other words turn clockwise 90 deg.
Don't forget to put it back before you want to go out next time.
Once turned off, run the engine till the fuel in the carbs runs out. You will hear the fuel pump making a noise, don't let it run too long like that though.
Post  randomeclipse Sun Dec 22 2013, 14:27
SteveCat wrote:Remove the seat, undo the bolt holding the tank, lift the tank up about 6". Look for the fuel pipe from the tank, feel along it till you get to the tap. the lever is pointing downwards, turn it from 6 o' clock to 9 o' clock, in other words turn clockwise 90 deg.
Thanks for that, Steve.
randomeclipse
randomeclipse
Post  Bikerchris Sun Dec 22 2013, 14:50
i do nothing, start fine and runs perfect after been stood over winter  Smile
Bikerchris
Bikerchris
Number of posts : 160
Registration date : 2013-01-11
Post  randomeclipse Sun Dec 22 2013, 14:55
Bikerchris wrote:i do nothing, start fine and runs perfect after been stood over winter  Smile
I imagine the same would be the case for mine, but if there's anything I can do to help her along I'd like to Smile
randomeclipse
randomeclipse
Post  Wooster Sun Dec 22 2013, 15:20
Same here.
I do disconnect the battery.. and fire it up for a few minutes every month (when I remember to do it), but that's about it.
It generally runs a wee bit lumpy for a few minutes come spring, but a blast down the dual carriageway and back at high revs clears it out.
(Worth noting that the tyres can be a bit greasy on the first run after standing for so long, so easy on the corners)*
*...both the engine and the tyres seems to need at least one good heat cycle through them.
Post  Tom... Sun Dec 22 2013, 16:07
Anyone got an idea why mine dislikes starting after being stood? She needs full choke and turns over for about eight seconds before firing and starting. Even then she's lumpy as hell, and has to warm up on 3/4 choke for ten minutes. Then after going out for a run, or being used once a week, she starts instantly, within turning over twice we're in business and it's unstoppable. I've a mint, original, engine that's not even done 3k miles from new! Sometimes I even miss my injected SV650S.... But then I go for a ride and remember why it was rubbish.
Tom...
Tom...
6Bronze
6Bronze
Post  bobh Mon Dec 23 2013, 16:57
I used to find it helped to put top-grade petrol (V-Power or similar) in if I knew it was going to be unused for more than a couple of weeks. I think it's cleaner and has less tendency to form a gel in the jets when it evaporates out of the carbs.
Post  kwakkat Tue Dec 24 2013, 12:24
good clean lift bike of wheels so you can spin the wheel make sure brakes are well cleaned spray with ACF 50 run bike every week end battery on trickel charge covered over with frost free heater in shed
pete
kwakkat
kwakkat
