Chain Splatter
mikeyzf600
Chain Splatter
I was removing one of the pesky fairing fixings on the underside of the 'cat today and finally managed to get it out - Hurrah!!
However, while my head was under the bike, I noticed clumps of chain splatter underneath which had been flung from the chain, and I know that there's some behind the front sprocket cover too.
So I was wondering, what do people use to clean it off? I'm thinking scraping it off with a credit card or something similar and then getting a degreaser to sit and dwell on it and then clean it off? Any suggestions?
mikeyzf600- 6Silver
Re: Chain Splatter
I try to avoid smoking all the time Would petrol be OK on the paint?
Regards,
Regards,
mikeyzf600- 6Silver
Re: Chain Splatter
That's a good plan. (I'll stop again......eventually )
Petrol shouldn't affect the paint much if it's wiped down (or everyone's petrol tanks would be stripped bare due to spillage )
I'll have a dig around tomorrow.
I used to use a citrus based solvent that worked an absolute treat on oil and grease to printer ink, but ran out of it and only found one supplier in the UK that stocked the stuff, Problem was they had a minimum order of 24 cans.
It was the best (and least carcinogenic) degreaser I've ever used.
Re: Chain Splatter
That's what they all say!
Yeh that's true. I guess if it's cleaned properly afterwards then it shouldn't be a problem!
OK, thanks! Would be interesting to see what it is.
mikeyzf600- 6Silver
Re: Chain Splatter
Get the bulk off physically then something like Muc-Off will shift it, or failing that some WD-40.
Re: Chain Splatter
As Wooster said a rag with petrol on will clear it off instantly. Just be ready with a bucket of soapy water straight after. Alternatively you'll be amazed by the cleaning power of WD 40. It is brilliant for getting any and all goopy, oily deposits off, just liberally soak the affected area for a few minutes then wipe with a cloth.
Re: Chain Splatter
Scrape it off with anything you can, lollypop stick, credit card type thing, spatula from the kitchen but don't let the missus find out... IT HURTS
Then when you've got the big bits off use baby oil on a rag it's amazing, same for your wheels and swingarm
Re: Chain Splatter
[You must be registered and logged in to see this image.]mikeyzf600 wrote:So I was wondering, what do people use to clean it off? ...Any suggestions?
I've been using Gunk since I started motorcycling way back when...
Tee-Forty- 3Silver
Re: Chain Splatter
I made the mistake of buying some cheaper own-brand Gunk-type stuff - useless. Stick with the genuine article (or Jizer, if it's still available).
» New cam chain & now I don't like it
» Chain lube
» Loose Chain
» Chain adjuster block?
» chain tensioners
» Chain lube
» Loose Chain
» chain tensioners
