C# programmers
question C# programmers
Post  Derek! Fri Oct 12 2012, 21:49
Hey everyone,
are there any C# programmers on here? I need some help converting xml files to pdf in a windows form app without using any add-ins (btw I use Sharpdevelop not Visual Studio if that helps).
If anyone know how to do that please would you help me Smile thanks.
Derek!
Derek!
Number of posts : 36
Hobbies : Programmer
Registration date : 2012-10-05
question Re: C# programmers
Post  billyw Fri Oct 12 2012, 22:02
Lost me at C#, sorry.
Hopefully some more enlightened pc punter will be along shortly.
Post  Derek! Sat Oct 13 2012, 00:18
billyw wrote:Lost me at C#, sorry.
Hope so too Billy, I wish developing windows apps was as simple as web apps
Derek!
Derek!
Post  Rosco Sun Oct 14 2012, 00:59
I work in IT but don't program anymore.
Used C 20 years ago at Uni but just managed to C past it.
This won' help either but this definition just needs saying...."Debugging: Removing the needles from the haystack."
Good luck
Post  biscut Sun Oct 14 2012, 16:38
hiya, I work with a bunch of programmers so have asked one of them if they have any idea's on the easiest way to do it. Will give you a shout if they come back with anything sensible, sadly i dont program myself. If it was network related then I might be able to help more...sorry.
biscut
biscut
Number of posts : 217
Hobbies : IT Geek
Humour : dark and perverted
Registration date : 2012-09-20
Post  SteveCat Mon Oct 15 2012, 09:53
Sorry, no help from me either - we're a Java shop, no idea on .Net
Post  biscut Mon Oct 15 2012, 15:16
hi Derek
Not sure if the below is of any use to you or not but its the answer I got back from the programmer bods at work...might give you somewhere to start but might also make things more complicated too...
"Have a look at Report.Net (http://sourceforge.net/projects/report/) which is a C# library for PDF generation. Obviously you'd need to determine how you want to visualise the data stored in the XML file, but this should give you the means to generate what you need to."
biscut
biscut
Hobbies : IT Geek
Post  Derek! Fri Oct 19 2012, 18:48
Hey guys, thanks for the replies Smile Been quite busy and didn't have a chance to log on... I managed to write my own reporting system and generate the reports to pdf using an open source library called sharpPDF left thumb up
Thanks for the link biscut, will check it out and maybe use it in the future Smile
Steve I'd like to learn to program in Java but everything just seems so complicated, one day I'll make some time for it.
Derek!
Derek!
