Paddock Lift Stand
Paddock Lift Stand Empty Paddock Lift Stand
Post  TomCom Mon Sep 10 2012, 16:18
i gat nice paddock stand on ebay for only 21.99 £ if you want to get one this link will get you to ebay: link
Paddock Lift Stand Empty Re: Paddock Lift Stand
Post  lankywardy Mon Sep 10 2012, 23:56
Hi does this work well with the thundersplat?
i wanna get one for general maintenence but i dont dare risk buying something that wont fit
lankywardy
lankywardy
Number of posts : 6
Registration date : 2012-09-08
Post  Rosco Tue Sep 11 2012, 00:16
As long as they are adjustable width (which these ones appear to be) then it should be fine for the thundercat type of swingarm.
The one I have (Micron) has rubber covered U shaped cups which give me a little bit more piece of mind when lifting.
I'm sure Tom will be along shortly with some info on how his performs.
Post  lankywardy Tue Sep 11 2012, 00:52
thanks rosco, yer i dont seem to keen on the fact its metal on metal, may have to do some customizing
lankywardy
lankywardy
Number of posts : 6
Post  stevemcc Tue Sep 11 2012, 00:56
This is exactly the same as the one my cat is currently sat on, albeit mine is red.
I can confirm it fits fine, the L section cups that sit against the swing arm are plastic coated so no problem, been using mine for nearly a year, still looks new, solidly built and pretty bomb proof.
stevemcc
stevemcc
Number of posts : 192
Hobbies : Aviation Engineer
Post  HEHORE Tue Sep 11 2012, 08:20
Front and rears set paddock set worth a look at
