Removing seat without key..
covcat
Removing seat without key.. Empty Removing seat without key..
Post  covcat Sat Sep 01 2012, 14:55
Is it possible to remove the seat without the key?
I have lost the key and suspect ive put it under the seat.
Can i remove the seat without the key?
I have put a magnet on the battery tray to see if it would attract or rattle...but no luck.
Can you buy keys to fit the barrel from Yamaha?
thanks
covcat
covcat
Number of posts : 67
Registration date : 2012-03-24
Removing seat without key.. Empty Re: Removing seat without key..
Post  0ldcat Sat Sep 01 2012, 19:17
You're not the first to do this . . . . . . and yes you can open / unlock the seat without the key. There is a thread on this one somewhere, I just can't be a**ed to look for it at the mo Guinness Wink
I believe it is or has to do with a steel wire that operates the release mechanism when you turn the key. Find this wire with the deft use of a coat hanger and yer in . . . . . as far as memory serves.
Sorry can't be more help than that wink thumb up
Post  weasley Sat Sep 01 2012, 21:06
That's pretty much it. I actually had a look for that other thread but couldn't find it. The lock pulls on a short cable which unlatches the seat. You have to be able to pull on this cable. Last time we discussed this I suggested removing the seat lock and simply tugging it to pull the latch open. The lock is held on by two security Torx bolts.
Post  covcat Sun Sep 02 2012, 20:47
Awesome,
thanks lads
More than helpful enough.
I just hope the key is under there...
covcat
covcat
Post  mrfrance Sun Sep 02 2012, 22:48
I hope for your sake it's under there too! Shocked
Have you checked your back pocket Don\'t Know green smile
On second thoughts if they are under your seat... I smell a numpty point coming on?!?
Post  YZFJohn Mon Sep 03 2012, 17:31
More radical would be to drill a hole from under the wheel arch and pop the latch with a flat head screw driver and then fill the hole with mastik.
As I said, radical and last hope and you would have to have a good idea where the latch is located which I dont think would be to difficult to work out.
Good luck.
Post  stretchie_ Mon Sep 03 2012, 17:55
I once had to pull the back of the seat up and get a neighbour with small hands to get in there and fish around for the keys.
I blamed Topdec....
Post  Panzerbuilder Mon Sep 03 2012, 19:47
Sounds simple but did you get two keys with the bike? If so can you find the spare one?
Post  covcat Sat Sep 22 2012, 12:51
I unscrewed the lock barrel from the bracket and just pulled it.
The Key isnt under there :(
Ive never had a spare and should have got one cut....but isnt hind sight a cruel mistress!
covcat
covcat
Post  mechy69 Sun Sep 23 2012, 09:45
when stuck when my key broke i just removed the plastic side panel, and simply used the allen key to pull the wire ,,,
