Starting my CAT project
Hi all
I am going to be starting my CAT project any week now, just wanted to see/check if anyone has any suggestions on upgrades, checks and maintenance I should do while the bike will be stripped down. Your know things like parts to clean and check which you would normally struggle to reach etc.
An advice would be much appreciated
Re: Starting my CAT project
Back light swap to cbr love it
indicators in mirrors
Heated grips
and DIGITAL clock next to speed clock so you know what time is
Heated grips
well i would check the swingarm linkage bearings , they need checking and greasing
mechy69- Event-Organiser
Just looking on ebay and seen these rear brake light LED and has integrated turn signals looks nice
http://www.ebay.co.uk/itm/350584922949?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649#ht_5080wt_1105
Wouldn't bother with that tail light personally. You are just asking to be rear ended with it. The brake light hides the turn signal and vice versa. If you've ever followed a Golf/Eos/VW with the circular lights you will get the idea.
Braided lines and R6 calipers
Perhaps consider buying some ACF 50 to spray into the harder to reach areas?
mikeyzf600- 6Silver
mikeyzf600 wrote: If you've ever followed a Golf/Eos/VW with the circular lights you will get the idea.
+1, I followed a Passat right onto the bumper not having seen those lights :(
mechy69 wrote:well i would check the swingarm linkage bearings , they need checking and greasing
+1 to this, and as I've said before, as you are stripping it make notes of the things that need replacing and the things that you'd LIKE to replace. That way you'll not forget the bits that need replacing and if money starts getting tight you'll be able to see which are the NEEDS and which are the WANTS, it might help to note how easy it is to get to these parts, if you have a want and it's in a right pig of a place to get to when the back is together and the engine in you might as well upgrade it to a NEED.
Oh and buy a load of take away plastic tubs with lids otherwise you will lose parts and bolts and it will annoy and worry the bejesus out of you.
» Trouble starting(even bump starting)
» trouble starting from cold
» Starting my Thundercat
» Starting the cat after winter - Help
» Starting to ride
» Starting to ride
