Petrol tank
Petrol tank Empty Petrol tank
Post  TomCom Mon Feb 13 2012, 18:24
i have full tank of petrol in old bike but after someone try to stell bike key not working anybody know how to change key lock from tank ?
Petrol tank Empty Re: Petrol tank
Post  SteveCat Mon Feb 13 2012, 18:52
Think you will have to take the whole silver assembly off, if you want to get the petrol out, let it drain through the fuel tap.
I seem to remember there are two screws holding the locking mechanism in place, you need to get these out to get access the lock barrel.
Post  bobh Mon Feb 13 2012, 19:16
SteveCat wrote:Think you will have to take the whole silver assembly off, if you want to get the petrol out, let it drain through the fuel tap.
On some Yamahas (not sure if it applies to the Thundercat, but it certainly did on the XJ900S that I had) one of the screws holding the cap surround is actually under the cap, presumably as a security measure. Which is a b****r if you can't open the cap! Mad
Post  TomCom Mon Feb 13 2012, 19:37
i got info from other forum. there is no way to take cap off without key :(
Post  SteveCat Mon Feb 13 2012, 20:13
You got nothing to lose, try taking off the whole cap assembly by removing the Allen bolts. The workshop manual don't show anything about the cap, so no help from there.
You do need to get underneath the cap to get to the lock mechanism.
What is happening when you try the key? Does the key go all the way in? If so is the problem that you can't turn it?
Post  TomCom Mon Feb 13 2012, 20:31
thief try to drill ignition and tank i don't know why so key is useless
Post  Snowcat Mon Feb 13 2012, 22:36
If the barrel has been drilled the lock is knackered anyway but the drill will have probably softened up the insides of the lock. You've nothing to lose getting a big screwdriver in the lock and forcing it open.
Are you just opening it to replace it or is there another reason??
Post  TomCom Tue Feb 14 2012, 11:45
i dont know what to do
sell it for part?
sell it like it is?
i will like to repair but have no money :(
Post  Guest Tue Feb 14 2012, 17:29
i will like to repair but have no money!
there is your answer. Rolling Eyes
Post  SteveCat Tue Feb 14 2012, 17:41
tomcom wrote:i got info from other forum.
Which forum was this?
Post  TomCom Tue Feb 14 2012, 17:53
i am not sure i think it was on scottishbikers.co.uk
