Enybode ever use "quicksteel" ?
Enybode ever use "quicksteel" ? Empty Enybode ever use "quicksteel" ?
Post  TomCom Tue Jan 24 2012, 09:54
i will try repair crankcase cover with "quicksteel"
did anybody use it?
Enybode ever use "quicksteel" ? Empty Re: Enybode ever use "quicksteel" ?
Post  Panzerbuilder Tue Jan 24 2012, 23:12
We use her-metal at work but this is more for structural padding out rather than repairs. It may have an issue with the vibration and if it needs to provide a seal then you may be asking too much.
Post  Rosco Wed Jan 25 2012, 00:20
When you say repair is it just cosmetic or does it have a hope in it?
If cosmetic you might want to consider carbon covers. Guy in Germany sells them.
If not then a second hand one might be cheapest alternative to buying a new one.
Good Luck
Post  TomCom Wed Jan 25 2012, 19:41
crankcase cover its broken on old bike
Post  Guest Wed Jan 25 2012, 20:02
JB weld is a good repairer.
I've used several times over the years the last being .....
I've used on my old T500 two stroke.
repaired a alloy finn never broke or shake of.
and 2 stroke vibs like no other.
I highly recomend this stuff to any one.
http://www.ebay.co.uk/itm/J-B-KWIK-original-cold-weld-adhesive-metal-bond-QUICK-/290505057832?pt=UK_Measuring_Tools_Levels&hash=item43a3736628
Post  TomCom Wed Jan 25 2012, 20:06
so is that "Quicksteel " is not good?
Post  stevemcc Wed Jan 25 2012, 20:23
I 've been using this stuff for years, all be it under a different trade name.
I work on aircraft and believe me a 2 stroke has nothing on a turboprop aircraft when it comes to vibration.
I have used it mainly for temp repairs on fuel leaks, it "goes off" fairly rapidly, it can be ground/filed down to a smooth finish and even painted over. It also works good as a filler.
A word of caution though, Dont use it where there is alot of pressure behind it, 100psi + as it will eventually start leaking again. very good as a get you home measure though.
I say go for it just make sure you mix it well before applying.
stevemcc
stevemcc
Number of posts : 192
Hobbies : Aviation Engineer
