clicky click
mdrb1979
clicky click
is this common
when i wheel the cat out and forward of garage there is a load audible click and the speedo needle jumps. (engine off)
mdrb1979- 3Bronze
Number of posts : 24
Registration date : 2011-08-28
Re: clicky click
No that not normal. How much does it jump?
Does the speedo work OK whilst you riding the bike? Can you tell where the clicking is coming from? the front wheel maybe?
Re: clicky click
Sounds like a cable or drive issue.
Re: clicky click
SteveCat wrote:No that not normal. How much does it jump?
Clicking i think is from the front, speedo is fine on road apart from a wobble at low speed(0-10mph) when slipping the clutch?
mdrb1979- 3Bronze
Re: clicky click
As RC said, it sounds like the speedo cable needs lubed.
If it's catching against the sleeve then it'll release and give the speedo drive on the front wheel a kick.
Course, it could be the speedo drive itself that's a bit on the dry side...or worn out.
Re: clicky click
Wooster wrote:As RC said, it sounds like the speedo cable needs lubed.
excuse my stupidness but where shall i apply lube
mdrb1979- 3Bronze
Re: clicky click
To be thorough you should really lube the entire cable.
That involves disconnecting where it connects into the 'dashboard' speedo. Can you spin the cable easily? And letting some engine oil or other suitable lube drip down.
Disconnect at front hub area using molegrips or pliers. Watch the innards don't fall out completely.
Wait til lub drips out.
Carefully ( it is near the brake discs after all ) lube the drive unit at the front hub and then pack with some Molybdenum grease.
Pack the bottom of the cable with some grease too.
Connect them all up and try moving it again.
Re: clicky click
0ldcat wrote:Fnar Fnarmdrb1979 wrote:excuse my stupidness but where shall i apply lube
Friznit Friznit.
P.S. I'd also check that the speedo drive itself is locked in place...something I forgot to do when I took the front wheel off for the first time.
There's a slot on the top of the drive that fits over a raised lug on the inside of the fork to stop it rotating.
