Speedo wobble!
Speedo wobble!
Hi all ive got a problem with the speedo on my cat. At speeds over 50mph the needle is all over the place and gets worse the faster I go. Any ideas? Thought it might be the cable??
Jtpt2007- 1Silver
Number of posts : 120
Re: Speedo wobble!
Cable or the drive hub in the front wheel or even the clutch meter (tabbed washer inside the wheel).
I've been through 2 pick-ups (gear unit assembly) and clutch meters and still on the same cable
Might be worth checking the cable is screwed in tightly first, it does have a tendency to come loose. Catch it before it comes out and you lose the cable.
Re: Speedo wobble!
Cheers I will check them out later and thanks for the rapid response
Jtpt2007- 1Silver
Re: Speedo wobble!
When Im at speed my speedo has always given me a fault code but never materialised into anything...Strange
Re: Speedo wobble!
ellie wrote: a fault code
what sort of code? 59th bridge song ? (slow down you move too fast )
Re: Speedo wobble!
Maybe it's lottery numbers! Spooky!
YZFJohn- 5Gold
Re: Speedo wobble!
ellie wrote:When Im at speed my speedo has always given me a fault code but never materialised into anything...Strange
Lol , this is another example of things being really complicated - I never really understood the tacho ( isn't that what you get in a Mexican ? )(like suspension settings -I mentioned this in a different thread) and now we have to crack codes whilst we are riding
Re: Speedo wobble!
