Thundercat tweaks!
Cheshirecat
Spartan
Thundercat tweaks! Empty Thundercat tweaks!
Post  Spartan Sun Jun 30 2013, 21:04
Gt my first Cat, and im just curious about what members done to improve it. The gear box , seems..well alot to be desired, my bandit gearbix was a lot slicker. I tried a few cats and it seemed common dog with them.
But what has the community done to Cats thats now common after market fixes
Spartan
Spartan
Number of posts : 20
Registration date : 2013-06-23
Thundercat tweaks! Empty Re: Thundercat tweaks!
Post  Cheshirecat Sun Jun 30 2013, 21:32
Make sure your chain and sprockets are in good condition and adjusted correctly, decent exhaust, good oil and air filter and that's about it from me,
Cheshirecat
Cheshirecat
Number of posts : 498
Humour : Humour??
Post  Spartan Sun Jun 30 2013, 21:36
It badly needs new chainset which is gettin ordered tomorrow.
Spartan
Spartan
Post  Tee-Forty Mon Jul 01 2013, 03:34
Spartan wrote:It badly needs a new chainset...
That could be the reason for the rough gear changing. I've found that mine is a bit slicker when the chain is adjusted correctly.
You could also replace the rubber brake lines with some braided stainless steel items, unless that has already been done.
Tee-Forty
Tee-Forty
Post  Spartan Mon Jul 01 2013, 07:56
Yep new chainset is must, been looking at Goodridge lines for brakes, had them for bandit...fookin night n day!
Spartan
Spartan
Post  bobh Mon Jul 01 2013, 23:01
There's a definite technique for smooth gearchanges. Take your time, stroke the lever, don't stab at it, and keep your toe on it until the clutch is biting and you're sure the gear has gone in.
I know some do clutchless upshifts, personally I prefer a "half-clutch" method, i.e. just pull the clutch in to the bite point, no further.
Post  Spartan Mon Jul 01 2013, 23:03
I try to get into second before revs are high cos it sure doesnt like that 1st to 2nd transfer!
Spartan
Spartan
Post  eccles291 Mon Jul 22 2013, 23:16
Change the fork oil and replace it with slightly heavier weight oil... use 10WT as opposed to 5WT IIRC. (It's been a while since I had my 'Cat).  While you're on with the front end, drop the yokes down the fork legs about 15mm, (i.e. - so there's about 15mm of fork tube visible above the top yoke) it'll sharpen up the steering a bit without making it twitchy. Thumb
eccles291
eccles291
Number of posts : 15
Hobbies : Job? Saying "Yes, dear" at home. Hobbies? Bikes, of course!
Registration date : 2013-05-26
Post  stretchie_ Wed Jul 24 2013, 15:53
Change the fork oil for 10w as above (and change springs if either higher mileage or just old), get suspension set up possibly new shock but that costs £££s but would be worth it and RRRRRRRRRRRRRRRRRRRRRRIDE the mutha
Post  Cheshirecat Wed Jul 24 2013, 16:42
I'd agree with the fork oil sap to 10w I did this when I dod the fork seals, springs and rear shock are fine on mine for the minute, think they were done by previous owner...
Cheshirecat
Cheshirecat
Humour : Humour??
